Fixed MOP, ne code comes up. help
Old Feb 28, 2006 | 10:01 PM
willub and company's Avatar
Pobody's Nerfect
so i had a problem with the harness going to the metering oil pump. the drive belt going to the air pump had warn through a few of the wires. someone pointed out that a MOP code would put the computer into "limp mode" causeing it to run like crap which it has been. i fixed the harness one wire at a time and the code is still there plus, it still runs like crap and a code for the knock sensor (5) has been added to the list. please help. the 5 never came up before. only mods are a gutted precat and apex'i exhaust. please help. thanks.
Old Feb 28, 2006 | 10:09 PM
Pobody's Nerfect
sorry for the spelling in the title. should say NEW instead of NE.
Old Feb 28, 2006 | 10:33 PM
tt_13b93's Avatar
un hook the battery, then hold the brake petal for 10 seconds and that should reset the computer then try it again, if its still doing it maybe it shorted the omp and it may need to be replaced.
Old Mar 1, 2006 | 06:43 AM
Pobody's Nerfect
****, you know what. i think i did short it. i was having my electrcian friend do the wring and he insisted that the battery didnt have to be disconected. he shorted some wires. i remember now. we tried reseting the codes. but what about the knock sensor. is that tied into that system??
Old Mar 1, 2006 | 06:55 AM
Gadd's Avatar
Warming the planet.
The Knock sensor is above the trailing sparkplug on the front rotor housing with a single wire going to it. check the wire and the connector, it may have been unpluged or the wire damaged when you changed the plugs.
Old Mar 1, 2006 | 08:32 AM
Pobody's Nerfect
ok i think i might have pulled on it and disconnected it when i tried to get of the MOP harness.
Old Mar 1, 2006 | 08:34 AM
Pobody's Nerfect
i have a spare pump. do you think i should just replace it all together or just try and trace the problem? is there a fuse for this that would have burnt out??
Old Mar 1, 2006 | 09:12 AM
tt_13b93's Avatar
i would replace the whole thing, and i had your problem before, when i replaced it the knock light went off. i think whenever the knock sensor has to work it trips a code that throws the car into limp mode. the reason the knock worked is because you had no oil being injected into your rotor housings.
Old Mar 1, 2006 | 09:18 AM
Pobody's Nerfect
ill probably do that. thanks
Old Mar 1, 2006 | 09:59 AM
Gadd's Avatar
Warming the planet.
The pump has nothing to do with the knock sensor, but the wiring may run thru the same place you made the repairs for the pump wiring. Did you clear the code for the pump? If you did there would be no reason to repace it. Inspect the knock sensor and wiring.
Old Mar 1, 2006 | 10:17 AM
tt_13b93's Avatar
He said its throwing both omp and knock now. but yes check the knock first b ut i think its the omp. also make sure the harness is plugged into the omp tightly.
Old Mar 1, 2006 | 12:58 PM
Pobody's Nerfect
i did reset it. when i first finished the wiring and got it all back together and plugged the battery back in, it pulled no codes. as soon as i started it up, it pulled all the codes (5 26 27). so it is somthing in the wiring. i think it was the short. BUT, couldn't this be a fuse that both the knock and pump are run through???
Old Mar 1, 2006 | 09:48 PM
Pobody's Nerfect
couldnt find a single blown fuse. i checked at the plug from the MOP harness to the main and it was not fully clipped but that didnt do anything. so F***ing frustrated!
Old Mar 2, 2006 | 12:58 AM
tt_13b93's Avatar
Hey, just trust me here. Replace the pump and save yurself some headache. make sure you have a 1/4" drive ratchet, long extentions, and a 10mm swivel socket. my '93 did it and my friend had a '95 fd that did it too. they threw your same exact codes. and if the other pump has another harness on it change that too.We wer beating our brains out trying to get it out of limp dick mode.
Old Mar 2, 2006 | 07:48 AM
Pobody's Nerfect
haha i will. i'll throw it up on the lift this weekend. i spent like two hours last night trying to find my mistakes and spent more time pissing myself off then finding anything . oh well . thanks tt 13b93. and Gadd.
Old Mar 2, 2006 | 02:09 PM
tt_13b93's Avatar
no prob. Let me know how it comes out, if it dont work you can kick me, lol but im 100% on this one.
Old Mar 2, 2006 | 09:22 PM
rx7will's Avatar
You can test the omp. Look in the service manual. All you do is check the resistance values of the wires. Its pretty easy.
Old Mar 3, 2006 | 11:11 AM
Pobody's Nerfect
yeah in know but i have a good one ready to go in and im pretty damn sure it is fried.
Old Mar 5, 2006 | 02:00 PM
Pobody's Nerfect
fixed it. what happened was when i fixed the wires before., it acctually was fixed. then when i started it up, they got caught in the main drive pulley and got ripped off. so i replaced them today (after finding the problem) and fixed the knock sensor which got ripped at the same time. nnow it is perfect. pulls like i always dreamed it would. thanks to everyone who had input.
Old Mar 5, 2006 | 02:01 PM
Pobody's Nerfect
oh yeah, it was just wiring not the pump itself. pump is perfect. im very happy right now
Old Mar 5, 2006 | 11:58 PM
tt_13b93's Avatar
Hell yea, good easy fix. Thought you would have checked that again though, lol but its ok, we all make mistakes.
Old Mar 6, 2006 | 10:25 AM
Pobody's Nerfect
yeah. atleast it's done and my car runs like it should. thanks tt
Old Apr 5, 2007 | 06:16 AM
ppiiggppoorrkk's Avatar
chris
yes i am a noob and i know this is an old thread but i actually did the same thing, my uncle helped me for a second and i didnt get everything hooked up yet and he cranked the motor and it ripped the wires from my mop, complicated story. the harness and all got ripped out from the connector,i dont even know which wire is which color , can i ask you to help me wire up my mop. i know thats the only problem and i dont have a service manual and this is my daily driver, ive been catching the bus to work all this time and need your assistance. i just need to know what wire goes where. only the nine total at the top connector and the three to the stepper motor i think and the six that goes to the pump? please help.
Old Apr 6, 2007 | 01:22 AM
chris
bump for help? can anyone please just take a picture of the harness wires in the connector?
Old Apr 27, 2007 | 01:45 PM
Pobody's Nerfect
I wish i had taken some pictures of this. and it has been a long time since i had to deal with this problem. bump to help this guy.
