Ground Zero Manifold and Y-Pipe FItment issues?
Old Feb 28, 2006 | 06:10 PM
dhahlen's Avatar
FD Under Construction =P
Got a friends ride who has EFINI Twins and a Ground Zero LIM.
The LIM was shaved to get the turbos to fit... and now the Y-Pipe is hitting the manifold.
Wondering if this is common, and if there is a common solution or some input on how to fix it?
Don't have pics, what I stated above is all I know right now.
Thanks
Old Feb 28, 2006 | 06:40 PM
DaleClark's Avatar
RX-7 Bad Ass
Well, the Groundzero LIM isn't designed for the stock twins AFAIK. You're gonna need to do some serious custom work to make it happen.
Dale
Old Feb 28, 2006 | 08:57 PM
GARCO MOTORWORKS's Avatar
Just twist the turbo intake housings (both) away from the motor .They will slip under the snap ring that holds them together .I tap them with a light rubber hammer to clock them in .
Old Feb 28, 2006 | 09:02 PM
dhahlen's Avatar
So basically clock the front one a bit to the left, and the rear a bit to the right, correct?
Old Feb 28, 2006 | 09:04 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
use longer studs in the rotor housings, and a racing beat (or whatever) exhaust flange with a gasket on each side.
Queppa
Nov 18, 2024 03:47 AM
msilvia
28
Apr 14, 2016 12:58 PM
diabolical1
30
Jan 30, 2016 05:50 AM
