car smokes- oil in intercooler! what wrong?
Old Feb 5, 2002 | 08:26 PM
defylogik's Avatar
ok, scenerio listen in title... what is most likely gone bad.. the turbo? a seal in the turbo?
thanks!
scott
Old Feb 5, 2002 | 08:51 PM
cymfc3s's Avatar
I Raise Chickens
turbo is bad. How many miles on it?
Old Feb 5, 2002 | 08:57 PM
akageals's Avatar
You can get a rebuild kit for the turbo with new bearings and seals for about $100.00. You might want to try turbocity.com (I think that was the site).
Todd
Old Feb 5, 2002 | 09:04 PM
defylogik's Avatar
this is the problem with a car im lookin at acquiring.. said it is a jsped with 30k miles on it..?
id assume bad turbo.. good reasons for upgrades..hehe
scott
Old Feb 5, 2002 | 09:39 PM
soul assassin's Avatar
GTR eater
i also vote for the turbo is hashed
Old Feb 5, 2002 | 10:41 PM
amemiya's Avatar
does your shaft wiggle?????? oh not that,,,, your durty,,,,,,, no seriusly does the turbo shaft wiggle. I would vote on turbo also but hows your power and do a leak down or compression test it could be blow by.
Old Feb 5, 2002 | 11:27 PM
Chance's Avatar
What color is the smoke and is the car hard to start? I'm curious as I have a similiar problem.
Old Feb 5, 2002 | 11:30 PM
TonyTurboII's Avatar
Glock Lover
Hm, I used to have this turbo that had oil in the compresser housing....but there was no shaft play whatsoever. I also had this weird smoke coming from around the turbo area, I swear it smelled like burning coolant.
Old Feb 5, 2002 | 11:35 PM
fastrotaries's Avatar
W. TX chirpin Monkey
My car only smokes when i shift it above or at redline. When the exhaust is hot though it just shoots a big *** flame.
Old Feb 6, 2002 | 12:09 AM
Chance's Avatar
Did you take care of the problem by replacing the turbo? Also curious if your car smoked at idle. What's going on with my car sounds a lot like what went wrong with yours. Thanks.
Old Feb 6, 2002 | 09:09 AM
akageals's Avatar
That coolant smell around the turbo can come from leaking intake manifold O rings. Yes...there is coolant running through the manifold and if the O rings leak the coolant may pool on top of the manifold and then trickle onto the turbo. I had that problem last summer....replaced the gaskets and O rings and no coolant smell since then. You might look for a white residue in the turbo area....it's a sure sign of evaporating coolant. As for the oil inside the compressor...a light film is normal...if it's pretty heavy i'd bet on bad seals inside the turbo. The seals can go bad without there being any shaft play (bearings).
Todd
Old Feb 6, 2002 | 11:12 AM
Barwick's Avatar
SCCA Rookie
Just like you said, you've got oil in your intercooler... that's the problem.
But seriously.. seeing as the turbo is the only thing with oil that is upstream of the intercooler, probably a bad seal would be my guess.
Old Feb 6, 2002 | 02:42 PM
Glock Lover
I replaced those o-rings in my manifold, and replaced the turbo (had a spare)...and it still smokes...
rotor_veux
46
Jun 12, 2018 10:39 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
