LED's
Old Feb 25, 2006 | 03:37 AM
Carzy Driver's Avatar
Law Breaker
LED's
Does anyone know how to wire them in? what resistors for what volts? how about bunch wiring? Just looking for basic help or a great write up. Thanks -Dave
Old Feb 25, 2006 | 07:07 AM
samiralfey's Avatar
Sisu, sauna and Sibelius
P=U*I
If you use it on your car then the voltage is around 12V and usually the voltage and amperes in a led is around 2.1 V(volts) and 20mA(milliamperes). From there we get:
12 V - 2.1 V/0.02 A = 495 Ohm resistor and the longer 'leg' on the LED is the positive(+) and short the negative(-).
The blue ones work usually at around 3.8 Volts. Check before you buy the resistors what is the specs of the LED.
Please somebody feel free to correct, long time since school...
Old Feb 25, 2006 | 01:15 PM
Corusco's Avatar
Depending on your application, you may be able to find the stuff you are looking for at Autolumination.com. If you are doing some custom wiring with loose LEDs, then samiralfey's math looks right...like he said just be sure to check your specs before you wire stuff.
Old Feb 26, 2006 | 08:36 PM
Law Breaker
thanks samiralfey and Corusco, both info helped alot
Old Feb 26, 2006 | 09:03 PM
audiobot7's Avatar
Ahh du ma! El Es Juan!
LED's looks ricey IMO
Old Feb 27, 2006 | 12:58 PM
Law Breaker
underbody LED's look ricey, these will in the interior and I'm only using 5mm LED's
Old Feb 27, 2006 | 04:13 PM
mbaha's Avatar
I have some that add 5hp EACH let me know how many you need.
Old Feb 28, 2006 | 01:33 AM
Law Breaker
I asked for help, not BS sales pitches
Old Feb 28, 2006 | 02:00 AM
axemurderer101's Avatar
check out my led's behind my speaker
before and after
Old Feb 28, 2006 | 03:01 AM
jic's Avatar
jic
volk racing
haha indiGLOO
Old Feb 28, 2006 | 03:04 AM
audiobot7's Avatar
before and after
You should get matching shift *****.
Old Feb 28, 2006 | 03:22 AM
NeedFD's Avatar
R. R. R.
add some glow in the dark panels, carbon fiber overlay, glow in the dark AND LED shifter, some hyperblue gauges and you can be in F&F3
Old Feb 28, 2006 | 03:25 AM
jic's Avatar
jic
volk racing
f anf f 3 gon be all driiffffftttttt
pfsantos
Sep 30, 2015 01:29 PM
TrboMike
NE RX-7 Forum
Sep 28, 2015 09:40 PM
