symptons of bad turbo?
Old Feb 5, 2002 | 12:51 AM
Chance's Avatar
What are specific symptons of a turbo on it's way out? Does smoke result from bad seals? Is the idle or anything else affected? Any other symptons? Thanks.
Old Feb 5, 2002 | 01:24 AM
cymfc3s's Avatar
I Raise Chickens
If your on the freeway, and you get off the gas and a plume of smoke comes out the back, its the turbo. If it smokes in the morning, its the oil seals in the motor.
Old Feb 5, 2002 | 01:28 AM
Scott 89t2's Avatar
SOLD THE RX-7!
if your intercooler piping is coated in oil on the inside, or if there is lots of play in the turbine (take off TID to check)
Old Feb 5, 2002 | 01:39 AM
Chance's Avatar
It just started to happen today. I started the car up after I got out of class and it kind of stumbled, and idled rough like it couldn't breathe. I try to rev it a bit and it was very unresponsive. On top of this, I noticed some grayish smoke, actually a lot, coming out the back After about 20 sec., it started to idle normally again and as I drove off, the smoke cleared. Pulled over to take a look and it wasn't smoking anymore. If I shut the car off for even a minute and turn it back on, the idle sounds funky for a sec and it smokes. I'm scared and confused
Old Feb 5, 2002 | 05:56 PM
Chance's Avatar
Started my car up this morning and no smoke. Started up fine without that clogged idling problem I mentioned above. I did this with the radiator cap off to check for bubbles also. That checked out as well. After I got out of class, I started the car and it idled like it wanted to die. When I tried to give it gas, I'd get a little backfire. On top of this, it's smoking pretty bad. I'll be checking the TID later today when I have time. In the meantime, any other suggestions to what it might be? Turbo or anyting else? Thanks.
Queppa
Nov 18, 2024 03:47 AM
cristoDathird
28
May 30, 2019 08:47 PM
Th0m4s
Feb 26, 2019 02:04 AM
cam_7779
Aug 18, 2015 07:48 AM
