Crazy Projects: Rotary on a motorcycle frame?
Old Feb 20, 2006 | 05:04 PM
ANGEL_OF_WAR's Avatar
Are there any rotary engines made by Mazda small enough to be mounted on the frame of a motorcycle? I mean, it would likely be a larger frame (goldwing-size) but is it possible?
Old Feb 20, 2006 | 05:43 PM
Maybe I can get a custom frame built around the engine...? Maybe that's the way to go.
Now since this is a motorcycle I'll have to mount the engine transverse...
Belt drive or chain? I'll have to figure out something...
These damned project ideas drive me nuts!
Old Feb 20, 2006 | 06:01 PM
SBMotors's Avatar
Feel the Experience
YES - go here and scroll down
http://www.dataphone.se/~berglund/wankel/swedenii/
Old Feb 26, 2006 | 07:29 PM
Hades12's Avatar
Burning Oil-Grinding 3rd
Guys build bikes with V8's So It should be easy enough to do one with a rotary
Old Feb 27, 2006 | 11:24 AM
rotary emotions's Avatar
HEAVY METAL THUNDER
Chrysler/Dodge even made one with a Viper engine... Anything is possible, if you know how and can raise the funds
Eamon Hurley build a Drag bike with a NSU Ro80 engine (highly modded) and those were 1.0l (= same size as a 10A). Van Veen used Comotor engines, basicly the same as the NSU. Norton used similar sized engines. So a 12A seems not that far of.
Biggest decision are wether to use chain/belt or driveshaft. If you go for a belt (or chain) you can opt for a setup as on most Harley Davidsons, and use a seperate gearbox. This would greatly simplify the construction, as the engine and 'box are seperate items, and frame rails can run in between for strength.
With a bike you don't need a flywheel (only a counterwheight and a starterring) nor a real alternator.
Custom frame seems only way to go, since the dimensions of a rotary are different from any "normal" bike engines.
But it'd be a cool project.
Old Feb 27, 2006 | 12:03 PM
Mordachai's Avatar
_
a long time ago, an old neighborhood buddy had an old suzuki RE5. We all thought it was the coolest 2 stroke in the world. He'd always yell at us " It's a wankel" ( but he'd say it Venckill - lol )
That thing was awwesome.
But yeah, with all the v8's and such in bikes, I don't see why you couldn't put it in a bike. Even mounted transverse, it's still a pretty compact engine.
|M|
Old Feb 28, 2006 | 08:53 PM
shepski's Avatar
600cc motor out of the suzuki RE-5 is your best bet, very compact. or you could chuck a 12A in if you want. but be aware the reason noone bought rotary bikes when they came out is coz they have a gyroscope effect due to the spinning rotors, with the small RE-5 cornering was difficult because the bike tended to pull straight and greatly understeer. id imagine this would be far worse with a big 12A or 13B in it. but prove me wrong if you want.
Old Mar 1, 2006 | 09:59 AM
saltyslug's Avatar
make it a trike like I am going to build soon, anyone got a one rotor laying around??
Old Mar 1, 2006 | 10:13 AM
Hades12's Avatar
Now that is a great Idea.
Old Mar 1, 2006 | 12:02 PM
Mordachai's Avatar
_
why the hell would you want a single rotor in a trike?
IT will be really underpowered, and hey- a trike can accomodate a much larger engine than a bike.
Old Mar 1, 2006 | 01:41 PM
fcdrifter13's Avatar
Play Well
From: We're all fine here now, thank you. How are you?
trike + 26b FTW
Old Mar 1, 2006 | 05:03 PM
Mordachai's Avatar
_
^ if you're balzy enought to full throttle it!
Old Mar 1, 2006 | 09:14 PM
shepski's Avatar
rotary trike would ******* rock the kazbar.
wouldnt have to worry about the gyroscope effect and allows much safer delivery of high power. with enough motivation you could easily fit in a 12A or 13B, not sure about 20B, not saying it isnt possible but youd have to do some planning.
doritoloco
Sep 8, 2015 07:58 PM
tonka_1956
Sep 2, 2015 05:55 PM
