Fuel pump replacement
Old Feb 4, 2002 | 04:09 PM
dwillms's Avatar
Hi, Im going out to buy a rx7 gen2 and the owner says the only thing wrong is the fuel pump is broken, so Im taking a working one out of one of my cars to test the car out before i buy it. Never taken one out or put one in before. Can some one lead me to a site with pictures and instructions? or provide some for me... Ive been search with little to no luck for the last 4 hours searching on my own.
thanks
-Daryl
Old Feb 4, 2002 | 04:38 PM
i dont have any pictures but i can explain how its done . first you take off the the plate in the back under the carpet on the drivers side . 4 screws . then you remove the fuel lines , 2 of them (mark them so you know wich one goes where when you put it all back together . next unplug the terminal . then you see around 8 smalls screws . be careful with them they can be fragile , but i didnt see to have a prob with them . after unscrewing those that allows the whole unit to be pulled out . you gotta kind of take it out at an angle . once you have it all out look for a screw on the bottom . unscrew that . then disconnect the positive and negative terminals . then all you gotta do is wiggle the old one out . put the new on in . hook up the terminal , screw in the bracket that holds the fuel pump in . drop the unit back in . make sure the 2 rubber nubs on the gasket push completly through the alignment holes . then put the screws back , the plug , and the fuel lines . and thats basically it . sorry for this cheesy as write up but it is pretty easy and self explanatory. let me know if theres something you dont understand.
later
Old Feb 4, 2002 | 04:42 PM
dwillms's Avatar
thanks - it doesnt sound too complicated now. Ill tell you how it turns out if i get that car or not!
-Daryl
Old Feb 4, 2002 | 04:47 PM
im glad i was able to help you out .. i did this the other day myself . it was pretty easy , and in your face . let me know how it turns out
later
Old Feb 4, 2002 | 04:55 PM
Scott 89t2's Avatar
SOLD THE RX-7!
there is some pics on my page. follow sig link to how to's to fd pump install. same thing.
Old Feb 4, 2002 | 05:01 PM
ralph f cooke's Avatar
later
please disconnect your battery before doing anything around your fuel tank that could conceivably cause a spark
Old Feb 4, 2002 | 07:48 PM
forgot about that part , i'd figure you'd have enough common sense to do that though .
Rotospectre
Mar 28, 2018 03:33 PM
alphawolff
Nov 17, 2015 05:57 PM
82streetracer
Aug 23, 2015 09:28 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
