Cleaned my injectors today!
Old Feb 15, 2006 | 11:57 PM
theagavejazz's Avatar
So I took off all 4 injectors today and cleaned them on the machine and now the car runs so good. It revs up soooo much faster than it did before and it runs much smoother. I never thought it would make suck a difference! Everyone should take your injectors to get professionally cleaned or do it yourself if you have access to machinery.
One problem, now car won't idle, I have to hold it on w/the throttle. Anyone know what could cause this idling issue?
Thanks.
Old Feb 16, 2006 | 01:16 AM
fc3stech's Avatar
From: San Bernardino County, Camp Pendleton, Kissimmee Fl.
yes a vaccum leak for one check all your lines, when you put it back together maybe you broke or cracked one
Old Feb 16, 2006 | 01:34 AM
88t2romad's Avatar
(_8(|)
did you replace your gaskets? Make sure the old ones were scraped COMPLETLY OFF. Then apply the new ones.
Old Feb 16, 2006 | 01:39 AM
eriksseven's Avatar
Make Money.
Huh... I'm jealous, lol. I had some injectors cleaned a while back and I didn't notice anything.
Good deal. I agree on the vac. leak causing the lack of idle. Spray 'carb-cleaner' around the engine bay and if the idle rises than you've found a leak.
Did you make sure to reuse the rubber O-rings for the injectors? If the seal isn't tight then you'll have some problems. Regardless, this does sound like a major vac. leak. Try the carb-cleaner spray trick.
Old Feb 16, 2006 | 03:45 AM
janm's Avatar
Hi, El Paso person
Where did you get your injectors cleaned? It'd be nice to be able to drive down there and have it done so I won't have to wait for shipping and stuff.
Old Feb 17, 2006 | 12:26 PM
Originally Posted by janm
Hi, El Paso person
Well I did them myself at my school. I know El Paso Fuel Injection will do them for $15 each. They're pretty good.
Old Feb 17, 2006 | 12:27 PM
I'm going to check for vaccuum leaks. I have a lot of line if I need to replace. That sucks if it's something under the UIM...
Old Feb 17, 2006 | 06:25 PM
Ok, I went out to check for vaccuum leaks and it turns out I forgot most of them, you see I was working on putting it back together really late at night. haha! I missed a big one by th MC, pressure regulator, one of the actuator ones, a couple above the oil sender, one from CC, and a couple others, plugged them in and car runs perfect now, I can't believe I forgot all that, I even forgot to tighten the two UIM bolts on the driver's side. Thanks guys.
Old Feb 17, 2006 | 07:39 PM
13angryB's's Avatar
I just got my injectors back from cleaning at www.witchunter.com
They did an excellent job.
$15 per injector, with free return shipping on 4 or more.
before I sent them out the injectors were all rusted & the red plastic was faded.
They cleaned up nicely,.. the metal parts media blasted to remove rust, the o-rings, pintle caps & screens replaced. And they somehow un-faded the red plastic tops!
after that they passed the flow checks:
; Leak Test, Spray Pattern, Static Flow, & Pulsed Flow @2500rpm..
The printout says they were within 6.3% of 550 cc/min before the cleaning & within 0.7% off after the cleaning.
Two of them run 542 cc/min @ 43.5 psi.
and the other two run 544 cc/min @43.5 psi.
Old Feb 17, 2006 | 08:12 PM
Beater86's Avatar
does anyone know why the primart injectors are such a bitch to get at...whereas the secondaries you can check/replace in like 10 minutes?
Old Feb 17, 2006 | 09:12 PM
because they are under the UIM. It really annoys me too.
Old Feb 18, 2006 | 12:38 AM
Alex6969's Avatar
The Silver Bullet
isn't a good idea to change those?
Queppa
Nov 18, 2024 03:47 AM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
