Fuel pump not getting any power?
Old Feb 15, 2006 | 07:15 PM
Andrew.'s Avatar
The end of an era
Yesterday while idling the car I turned on my heater and POP, car shuts off immediately. I go to turn the car back on, and my walbro didnt switch on (It didnt make its "whine") and all it did was crank over. So I swapped my na pump back in as well to check if the pump possibly went out and it also didnt turn on. Then I pulled out the good ol' dmm to check the voltage while and it was surging like: 0.97, 2.05, 4.08 and repeat...odd... Anyone have a similar situation? Thanks.
-Andrew
Btw I have a E6K and the car is NA
Old Feb 15, 2006 | 07:37 PM
arghx's Avatar
rotorhead
do you have the stock pump wiring? Or is it rewired directly to the battery with a relay?
Old Feb 16, 2006 | 12:06 PM
Andrew.'s Avatar
The end of an era
On that part i'm not certain, I let my friend deal with that as I have no experience with it. He spliced the black/with white stripes wire from the fuel pump and I have a wire going through my passengers side harness to the e6k harness.
Old Feb 16, 2006 | 03:56 PM
iceblue's Avatar
Passing life by
Check the main relay
Old Feb 19, 2006 | 06:36 PM
Andrew.'s Avatar
The end of an era
Um, yeah it starts again, checked my interior fuses, found a couple bad ones, swapped it, heard my whinebro whine and she fired right up!
Queppa
Nov 18, 2024 03:47 AM
alphawolff
Nov 17, 2015 05:57 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
