how do I change a rear wheel stud WTF!?!!!??!?!two
Old Feb 15, 2006 | 03:45 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
I'm trying to change a rear wheel stud on my 10AE.. I got the brake rotor off (pain in the ***, screws were sized on), got the big axle nut off (bent my breaker bar to do that), now I can't figure out how to get the abs sensor unit/hub off. Do I need to remove the wheel bearing or pull the whole hub assembly off to do this? what a pain in the *** this is turning into. I tried to force it off by unscrewing the dust cover bolts but all I managed to do was strip them since the hub is cast aluminum.
Someone please help me here. Thanks
Old Feb 15, 2006 | 07:10 PM
rodney87's Avatar
Yeah, you have to take off the whole shebang. IIRC you need to get the axel off and the whole ABS assembly, then when its off the car you can undo the back of it and you'll have access to the stud. Good luck.
Old Feb 15, 2006 | 08:00 PM
iceblue's Avatar
Passing life by
Negative you only have to remove the rotor on the rear. I have a artical on my blog. You have to fanagle the stud around in and out but you can get them in and out without taking the hub off. The front only requires the wheel to come off "duhh".
Old Feb 15, 2006 | 08:09 PM
NeCr0mStR's Avatar
I just wanna hump my car.
wheel studs aren't that challenging but its the rust that will be a problem... if you have a torch or some liquid wrench it helps... and when you put the new one on use an open nut to tighten it into place so you don't have to pound it in.
Old Feb 15, 2006 | 08:27 PM
Oni-kyan's Avatar
5one5innovations.com
when I cahnged two of mine I toke the wheel off and if you spin the rotor you will find looking from the back that there is a hole or grove anyway light up the stud with that and hit it hard if it doesnt work get a bigger hammer puting a new stud we sliped it in hit it once or twice the put a bolt or two(wider then the stud so it acts like washers) threw the lug nut on and used an impact gun tp pull the stud into place.
Now that I totaly confused you ill try to take a pic or two but im sorry i cant do it till friday hopefully someone else can better explane what im saying
Later Mael
Old Feb 15, 2006 | 08:31 PM
iceblue's Avatar
Passing life by
^ sounds like you removed a front. That little slot isnt like that on the rear.
Old Feb 15, 2006 | 08:36 PM
Oni-kyan's Avatar
was for me I do know for a fact it was a rear on my 86 gxl 5bolt might be diff but it was a rear
anyway might not have been a hole for it i guess but i never took the disc off so? a well who knows
Old Feb 15, 2006 | 08:46 PM
Oni-kyan's Avatar
dam ice
you made me go check but I cant get under to see well enough lol
so ill call you right although I never had to change a front one but when it comes to these cars you do tend to know more then me so
sorry dint mean to sound defensive and ***** like
later
Old Feb 15, 2006 | 08:55 PM
iceblue's Avatar
Passing life by
I may be wrong now that you brought up the lug pattern and the vented rotors. I havent done a 4lug so maybe there is room back there. On a 5 lug there is not.
Old Feb 15, 2006 | 09:16 PM
Terrh's Avatar
my car has ABS.
There is NO way for the stud to come out without removing the abs wheel.
There's no way to remove the abs wheel without removing the part the wheel bolts to.
so how do I remove that?
Old Feb 15, 2006 | 09:55 PM
iceblue's Avatar
Passing life by
Ah man you got jewd with that ABS. Sorry I have no clue without taking one of mine apart, and its late.
Old Feb 15, 2006 | 09:56 PM
Terrh's Avatar
the abs is the reason my front bumper is still as pretty as it is.
I love my abs, even if it's a pain in the *** sometimes.
Old Feb 16, 2006 | 07:48 PM
Terrh's Avatar
any more ideas? Do I need to take the whole hub off the car?
Old Feb 16, 2006 | 09:29 PM
rodney87's Avatar
I've got ABS and when I changed my stud thats what I had to do. Once the whole this is off its alot easier to see what your dealing with and what you have to take off.
Old Feb 16, 2006 | 11:33 PM
RoughRex's Avatar
It's Radiation Therapy
Man, I have a '88 GXL with two broken studs on the RR. I just can't wait to tear into that..... please save me from having to tear this whole hub apart.
Old Feb 16, 2006 | 11:42 PM
RotaryEvolution's Avatar
Sharp Claws
i had to remove the hub when i installed ARP wheel studs, talk about a royal pain in the ***...
Th0m4s
Feb 26, 2019 02:04 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
Marty RE
Aug 17, 2015 09:36 AM
