offset
Old Feb 13, 2006 | 05:20 PM
jgrts20's Avatar
Who are you?
offset
Will a 42 offset fit on my car? quickly have 3 hrs left
Old Feb 13, 2006 | 05:21 PM
classicauto's Avatar
Crash Auto?Fix Auto.
how wide are the rims?
and I believe fc3spro has a list of wheel fitment sizes and offsets - could be in FAQ though
Old Feb 13, 2006 | 05:28 PM
Rotary_Knight's Avatar
should be ok but it depends on the width
Old Feb 13, 2006 | 05:38 PM
Jager's Avatar
Tear you apart
If its a 7" rim nothing more then 40 is recommend. You can fit them but it may be VERY snug or it could very well risk rubbing.
Old Feb 13, 2006 | 05:47 PM
jgrts20's Avatar
Who are you?
17x 7 what do you mean by snug jager? I looked at the faz(I know about it) but was wonder if 42 would work fine, eventhough its recommend for 40
Old Feb 13, 2006 | 06:16 PM
AcidAngel7477's Avatar
We're All Fkd..
should be ok, it will come out past the fenderwell a little tho....
:AA:
Old Feb 13, 2006 | 06:25 PM
jgrts20's Avatar
Who are you?
cool thanx, but does anyone know anything about ADR rims? Also can you fit 235's on 17x7's?
Old Feb 13, 2006 | 08:00 PM
Jager's Avatar
Tear you apart
7" wide wheel isn't recommend with anything over with stock replacement struts and springs. You get 10mm either way with coilovers. 41mm and above can lead to possible rubbing.
Old Feb 14, 2006 | 03:40 AM
jgrts20's Avatar
Who are you?
Im running tanabe gf210's(drop of 1.5") with kybs(AGX). So its not stock anywho, thanx though I didnt get those rims.
chris
Old Feb 14, 2006 | 05:25 AM
RETed's Avatar
17" x 7.0", +42 should be okay with a 225 / 45 / 17 tire.
Going with the 235 wide tire, it might rub the insides.
You really should save your money before buying those cheap-*** Motegi / OBX / Nippon Racing / ADR crap though...
-Ted
Old Feb 14, 2006 | 03:08 PM
jgrts20's Avatar
Who are you?
what would be the offset for a 17x7.5 rim? can you fit a 235 tire on 17x7's for the rear?
chris
Old Feb 14, 2006 | 03:10 PM
Jager's Avatar
Tear you apart
-Ted
Sorry Ted .
Everything I think I learned about wheels was from you and your site, I should of waited for you to chime in.
Old Feb 14, 2006 | 03:11 PM
Jager's Avatar
Tear you apart
http://www.fc3spro.com/TECH/MODS/RT/rims.htm
Old Feb 14, 2006 | 03:12 PM
jgrts20's Avatar
Who are you?
wow sweet thanx Jager I needed that chart.
Old Feb 14, 2006 | 04:11 PM
jgrts20's Avatar
Who are you?
what do y'all think about these on a black car?
Old Feb 14, 2006 | 04:50 PM
We're All Fkd..
those arent bad i deal with adr's all the time....there good for tuner apps. as far as a 7? they wouldent look bad, just get the right tire....
:AA:
Old Feb 14, 2006 | 05:11 PM
jgrts20's Avatar
Who are you?
what would you suggest I run for tire on that type of rim. I thinking 235/45r17's rear and 215/45r17's front or 225/45r17's front. Would that suffice?
Old Feb 15, 2006 | 05:00 PM
jgrts20's Avatar
Who are you?
Guess what I just ran a check on the rims I purchased last year and they are 16x7's with a +42 offset. So I guess me purchasing 17x7 rims with a 42 offset will work, nice!!
thanx guys/gals
chris
doritoloco
Sep 17, 2015 03:51 PM
