Wheel offset question
Old Feb 8, 2006 | 11:05 AM
BigPimpin''s Avatar
Found a nice set of wheels and the price is right( free) but I'm wondering if they will fit. The guy says they are 4x114.3 +45mm offset. Will that fit? What is the offset on a set of stock se wheels?
Old Feb 8, 2006 | 11:24 AM
rotor vs. piston's Avatar
Function > Form
Stock is 40mm for the -SE. What size are the wheels? The only issue you might run into is in the front, depending on what springs you're running the tire may rub. Also depending on how wide they are, they may look a little to tucked in.
Old Feb 8, 2006 | 11:28 AM
BigPimpin''s Avatar
Wheels are 15x6.5.
diabolical1
30
Jan 30, 2016 05:50 AM
MILOS7
Aug 19, 2015 07:25 AM
