Dellorto Throttle linkage?
Old Feb 7, 2006 | 09:46 PM
MattG's Avatar
MattG FTW!!!!!
I have a Dellorto 48 DHLA. I have been itchin to get this bad boy on. It seems that my car wants nothing to do with it though. It has been one issue after another.
I am missing the throttle linkage. it never came with it. I contacted the guy I bought it from, but he didnt have it. He bought it but never put it on his car, so its not his fault.
Here is a pic of what Im talking about.
How am I supposed to connect the throttle cable. I know there should be a cruise one too, but I aint even trippn over that i just want to be able to give it gas. I really hate bootleggin things, yet I dont wanna have to order parts form the UK.
Sometimes I just wanna sell it and get a sterling!!!!!!! UGH!
Old Feb 7, 2006 | 10:57 PM
Rx7Kidd's Avatar
Sp33d D3m0n
try ghetto rigging it with a throttle cable end or build something. i dont think that the part is availible for seperate buying or ive never seen one.
Old Feb 7, 2006 | 11:09 PM
SonicRaT's Avatar
Super Raterhater
It is, it's really meant for a different style of throttle cable though, and you're going to have difficulties finding the parts locally.
I know exactly how to rig it and I'm trying to show hondalover what I mean so he can show you when you guys attempt it, but he's MIA as usual.
Old Feb 7, 2006 | 11:34 PM
SonicRaT's Avatar
Super Raterhater
Ok, here's what I told hondalover to do:
Take the old Nikki out of my FB (it's in the storage bin)
Break the choke cable linkage off (make sure you leave about at least a half inch to an inch of metal beyond where the cable connects to it at)
Drill a hole near the back of the 'new' linkage, close to where you broke it at
Find a bolt/nut combo that will bolt the 'new' linkage onto the hole at the bottom of the linkage on the dellorto, but this needs to be able to rotate and not have slack to flop around at all.
Then you should be able to mount your original cable directly to the old nikki choke linkage. It will look a little ghetto and strange, but it will work.
OR, if you don't care about hooking up your choke right now, take the cable holder off of that's linkage and relocate it to the throttle linkage, then find some way of making your stock cable fit on it and not come off.
Old Feb 8, 2006 | 12:12 AM
Siraniko's Avatar
RX for fun
That carb is missing the RB throttle linkage. two pieces of metal that sandwiches the throttle cable. Buy the holley linkage from kragen.
bad flash.
Old Feb 8, 2006 | 12:22 AM
MattG's Avatar
MattG FTW!!!!!
Wacky!!! GIVE ME GIVE ME GIVE ME!!!!
Old Feb 8, 2006 | 12:28 AM
SonicRaT's Avatar
Super Raterhater
Haha, yeah, the right part also helps.
Old Feb 8, 2006 | 12:30 AM
Siraniko's Avatar
RX for fun
Find a VW partshouse. they usually carry a universal linkage kit Or find an old pre-RX-7 nikki carb and grab it (requires little massaging). The one's from an RX-7 will not work as it uses a spacer. Too bad I didnt keep the orig one from this carb. I hated that POS.
Old Feb 8, 2006 | 12:39 AM
SonicRaT's Avatar
Super Raterhater
I'm pretty sure if you hack up the nikki choke linkage you can make that work until you get the proper one (as pictured above
Old Feb 8, 2006 | 12:42 AM
MattG's Avatar
MattG FTW!!!!!
Wacky your killing me bro!!! Its like showing a hungry man I picture of food!
universal linkage kit for what a dellorto?
Old Feb 8, 2006 | 12:46 AM
Siraniko's Avatar
RX for fun
lol. yeah, hit the junkyard. Grab the ones from F/I cars (MX-6 as in example) and have someone spot weld it. I dont recommend drilling/screwing it to the stocker as it can bind (learned that the hardway while on the track on 2nd gear-had to shut it down).
Old Feb 8, 2006 | 12:53 AM
MattG's Avatar
MattG FTW!!!!!
This Dellorto is starting to **** me off! Im about to give up and just sell it for a sterling!
Any takers!
Old Feb 8, 2006 | 12:58 AM
SonicRaT's Avatar
Super Raterhater
If you use proper hardware (ie not a fully threaded bolt), and grind all the corners down, there shouldn't be any reason for binding as there'd be no way for the nut to tighten itself on the bolt (as you'd tighten it down all the way until the unthreaded section), what binded up on yours? I figured so long as they were careful this would work ok temporarily, but that kind of makes me wonder now.
Old Feb 8, 2006 | 01:04 AM
MattG's Avatar
MattG FTW!!!!!
Yeah, that doesnt make sense to me. If I attached the linkage I got form the Nikki to that using a bolt through that small worn hole at the bottom I dont see how that would cause the system to bind sticking the throttle open.
Old Feb 8, 2006 | 01:07 AM
SonicRaT's Avatar
Super Raterhater
It would if you used a threaded bolt that would allow the nut to tighten down not allowing the linkage to rotate, as when the throttle came back it wouldn't rotate and it'd hold it open slightly. But I think so long as you put it together properly it would work fine.
Old Feb 8, 2006 | 01:15 AM
MattG's Avatar
MattG FTW!!!!!
if you tighten the nut fully on there with one of those nylon locking nuts it should lossen or tighten, staying with the unit moving as one. the same as welding it. I would weld it, but I left me welder back in TX.
Old Feb 8, 2006 | 01:20 AM
SonicRaT's Avatar
Super Raterhater
The cables going to need to be able to pivot, either within the peice you steal from the nikki, or on how you attatch it to the linkage already on it. Chances are there's not enough range for it to rotate in this setup with the peice you take from the nikki, so you'll need to make the assembly itself rotate, this is how it could possibly bind as it could tighten and stop rotating ending up at a strange angle.
Old Feb 8, 2006 | 03:10 AM
Hyper4mance2k's Avatar
The Shadetree Project
www.cbperformance.com <<<< they have everything weber you can think of. even the so call nonexistant dcoe rebuild kit.
Just realized it's a delorto, that carry stuff for those too..
LongDuck
Oct 7, 2015 08:12 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
