Have a question about fuels systems
Old Feb 7, 2006 | 08:48 AM
pyromasterpaintball's Avatar
I just got my t4 turbo installed in my fd the other day i was wondering, if i had to do a fuel system on top of this turbo upgrade, Do i need bigger injectors or will the stocks be fine, not to sure about what to do with this..
Old Feb 7, 2006 | 08:57 AM
finnicky7's Avatar
26.55 psi T04Z Monster
You need at the very least larger secondaries. 1200-1300's are the easiest cheapest solution. What type EMS do you have right now?
Old Feb 7, 2006 | 12:34 PM
I have stock right now but im getting a apexi power fc soon, i was ganan do this upgrade with the fuel system just needed a little more info on some things first thanks for the help
Old Feb 7, 2006 | 01:20 PM
fastcarfreak's Avatar
3rd motors a charm I hope
you actually need to upgrade your ecu before you do anything. The stock ecu will not control a single turbo car properly. Along with the ecu, you will need to upgrade your injectors and fuel pump in order to make any power greater than like 290-300 whp. I do not suggest driving the car without an upgraded ecu, it will cost you more to rebuild the motor, because it WILL break if you boost and are not carefull.
Adam
Old Feb 7, 2006 | 03:27 PM
Nuvolari's Avatar
Veni, Vidi, Vici
Good advice from fastcarfreak, your in the danger zone running a single with a stock ECU.
I would expect your going to get one PFC or something like it. Your going to have to upgrade your injectors. 1300cc secondary should do it, and from what I was told with a good tunner you can keep your 550 primary or go up to 650's . Your also going to need a boost controler. Join the "when will it end" club. Going single sounds simple but its not cheap
Old Feb 7, 2006 | 05:35 PM
haha yea i hear ya its really a never ending battle but i plan on getting new secondaries + the power fc+ the boost controller and all that other stuff thanks for the advice and help..
Old Feb 7, 2006 | 05:51 PM
do i need a new secondary rail to get the injectors to work or will they fit right into my stock rail..
Old Feb 7, 2006 | 06:34 PM
maxcooper's Avatar
WWFSMD
You can have the stock secondaries enlarged (by RC Engineering and others) from 850 cc/min to 1200 or 1300 cc/min. Those fit in the stock rail.
Or you can get a top-feed rail and use 160 lbs/hr (= 1684 cc/min, but commonly called "1600s") or other size top-feed injectors.
-Max
82streetracer
Aug 23, 2015 09:28 AM
