(INTERIOR) Instrument Cluster TRICK !!
Old Feb 6, 2006 | 08:11 PM
seldawg's Avatar
I just got done putting new white gauge faces in my 84 GS and they look great. I figured out a little trick I figured I would share with anyone who will be pulling the gauge faces for any reason. If you disconnect the speedo cable from the tranny you can feed it thru the firewall and it makes much easier to get the cluster out. This gives you plenty of room to get your hands behind the cluster and pull the rest of the connections. It took about 15 minutes total to get the cluster out and then back in once I replaced the faces. Hope it helps someone else.
Old Feb 6, 2006 | 08:28 PM
FirebirdSlayer666's Avatar
Famous Taillights
That's a damn good idea. That should get stickied
Old Feb 6, 2006 | 09:06 PM
seldawg's Avatar
and how do you do that ?
Old Feb 6, 2006 | 09:27 PM
1stgen4life's Avatar
Leaking oil like crazy!
Mods have to do it.
85rotarypower's Avatar
love the braaaap
Only a moderator can "sticky" a thread. This is a good idea, but IMO, not really worth it. if you know what your doing, you can pull a cluster in 5 min without pulling the whole speedo cable out.
EDIT: Damn, beat me to it.
Old Feb 6, 2006 | 09:35 PM
seldawg's Avatar
didn't pull the cable all the way out, just fed enough thru to get behind the cluster and disconnect.
Old Feb 6, 2006 | 10:42 PM
Directfreak's Avatar
I am a Jeeper Now.
I guess when I posted it here:
https://www.rx7club.com/showpost.php...97&postcount=6
In this thread:
https://www.rx7club.com/showthread.p...ghlight=speedo
And several times over the past few years, that it wasn't "archive" worthy.
Old Feb 6, 2006 | 11:05 PM
vipernicus42's Avatar
Rotoholic Moderookie
Lol, sorry Directfreak
I guess us omnipresent mods do miss things sometimes
Archived, *including* Directfreak's links to his original posts
Jon
