zero offset??
Old Feb 5, 2006 | 11:40 PM
MaX PoWeR's Avatar
Smoov-e "Dick Like Mine"
zero offset??
Any1 running 15x7 with a zero offset?? im friend is giving me his rims from an AE86 . hes giving it to me as a gift. and i was woundering would zero offset stick the rims out too much? do i have to roll the fenders flares? i just hope the rims have a more positive offset like +12. if any one has this set up, feel free to drop a pix. thx .o ya i got an se
Old Feb 5, 2006 | 11:47 PM
nick1's Avatar
is it a gsl-se or not
the gsl-se has +35 and the non-se has +20 i think
i have 15x7 with +7 on the front of my non-se, and the rim is very flush with the front fender. im hoping for 0 offset for the rear but that's just me.
i think it will be too wide either way to have to roll your fenders. they will stick out a bit
Old Feb 5, 2006 | 11:50 PM
MaX PoWeR's Avatar
it is an se
Old Feb 5, 2006 | 11:54 PM
nick1's Avatar
okay, so it will stick out even more than a non -se cuz your offset is +35
but it depends on what you want. i personally WANT 0 offset
Old Feb 6, 2006 | 12:01 AM
MaX PoWeR's Avatar
im just hoping it wont stick too far out. sticking out just a lil woun't matter to me too much. but im just hoping it wont stick out too far.
Old Feb 6, 2006 | 12:05 AM
MaX PoWeR's Avatar
o ya i just remembered that it had a 1.5 - 2 inch lip to it. if that matters
nick1's Avatar
it'll be pretty much flush with the fender...or maybe stick out a half an inch...or so
steve84GS TII's Avatar
FB+FC=F-ME
On an SE its gonna stick out a bit and rub.
My old 15X7 Centerlines had a 12MM offset and they would JUST barely clear with my SE rearend....after I rolled the fender lips.With the GSL rearend they cleared easily.
If it were a non SE you would just clear with rolled fenders,but on an SE and with no offset,its gonna hit unless you get drastic with the fender lips.
Old Feb 6, 2006 | 12:07 AM
nick1's Avatar
exactly.....real stiff suspension would help with the rubbing
Old Feb 6, 2006 | 12:11 AM
MaX PoWeR's Avatar
thx guys. ill c what i can do. if anyone got pix feel free.
Old Feb 6, 2006 | 12:45 AM
FB+FC=F-ME
Heres a few pics from WAY back in the day....
15X6 Boyds....with a non-SE rearend it was still close,but no rolling required.1" lowering springs.You get a little breathing room up front because the independant suspension will camber in a bit when it compresses.But the rear's solid axle will travel straight up,right into anything above it....
The inch wider Centerlines and SE rearend required rolling just to drive it with 1" lowering springs.I could just,just,just get away without fender rolling before the SE rearend.But later,the SE's wider brake rotor hats pushed the 7" wide/12MM offset wheels out too far and I had to pull out the Louisville Slugger.
Old Feb 6, 2006 | 01:06 AM
d0 Luck's Avatar
raysspl.com
here's 0 offset for ya
epsilons 16x8.5
they are for sale for the right price. PM me if anyone is serious.
here's what they could possibly look like on your FB, except they are 15"
Old Feb 6, 2006 | 01:16 AM
RE Matsuda's Avatar
Altered Beast
Here's a pic of my old SE for reference:
15x7 Riken; the fronts have +17 offset (pretty flush on an SE), and the rears have zero offset, which clearly stick out quite a bit. It would probably look good with low suspension (my SE had stock suspension) and rolled fenders.
Old Feb 6, 2006 | 05:50 PM
MaX PoWeR's Avatar
d0 Luck, on the red 7, does both front and rear have zero offset or just the rear? and thx to all that help
Old Feb 6, 2006 | 06:09 PM
SparkienSuggah's Avatar
buzzzzz!-ook!-buzzzzz!
Maxpower: i can almost help you.. i put stock MKII supra rims (14x7, near zero offset) on the rx (83 gsl) for ***** and giggles... its gonna look exactly like d0luck's... but it'll handle better than stock.
i hope you like fender flares.
Old Feb 6, 2006 | 06:21 PM
MaX PoWeR's Avatar
thats not bad. im just waiting till i get thoughs rims so i could post som pix. hes still looking for rims to put on his 86 befor hes giving them to me.
Old Feb 6, 2006 | 06:22 PM
d0 Luck's Avatar
raysspl.com
you don't want to run 0 offset in the front since it cannot accomodate lower offsets in comparison to the rear. your best bet is to run a set of staggered wheels. even then i don't suggest running low offset wheels since they would ruin wheel bearings with the quickness.
these advans SA3 i also have for sale 4x114.3 bolt pattern are staggered and would actually look good on a GSL-SE. they are forged lightweight 2 piece maybe 3 piece (depending on the way you look at it) wheels.
16x7 front 32+ offset
16x8 back 32+ offset
if anyone looking wants these wheels, just PM me.
i also have 15" SSR EX-C Formula mesh wheels for sale
here's a pic how they would look like on an FB
lastly, my AR Centerlines are what you would consider low offset wheels. 14x6.5 or 7" wide(?) but deep dished wheels. once again, they are also for sale and are a complete set of 4 wheels.
old school
doritoloco
Sep 17, 2015 03:51 PM
