TII swap in a SA 60-1 choice
Old Feb 4, 2006 | 03:08 PM
gonzz's Avatar
I'm having mj turbo shop build me a 60-1 turbo. The car is a RHD SA and installing a SP TII engine in it. I have a custom T4 manifold and 40 mm tial gate. What specs should i go with? I want around 400-450 max hp. A street tune of 380 or so.. what specs should i get on the turbo? Gonna order it on Monday.. Thanks..
Old Feb 4, 2006 | 03:29 PM
KNONFS's Avatar
B O R I C U A
My research showed that 450hp at the wheel on a 60-1 won't happen; 375hp low boost and 400hp on hig boost is about right for a 60-1 (more or less). If your max HP goal is dead set around 450hp, a T61 might be a better choice.
I ended up with a plain 60-1, less Hp on top, hopefully more responsive
Old Feb 4, 2006 | 03:33 PM
gonzz's Avatar
what kinda power did you get at what boost setting? 400 will be ok.. It's a 2k lb SA so will be pretty quick. what specs should i get?
Old Feb 4, 2006 | 05:03 PM
KNONFS's Avatar
B O R I C U A
I haven't finish the car yet, hopefully it will ready between april and summer
Old Feb 6, 2006 | 12:53 AM
gonzz's Avatar
This is what I'm going with....60-1 t04s front, .70 cold, .81 hot, p-trim
Old Feb 6, 2006 | 08:36 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
5th time this week
sctRota
Old School and Other Rotary
Nov 10, 2015 12:57 PM
