How much power with this set-up?
Old Feb 1, 2006 | 04:52 PM
red87tll's Avatar
needs a cheaper hobby
Just wondering if someone could give me an estimate.
Kevin Landers rebuild (3000 miles)
Street Port
3" DP, RB mid, custom 3" cat-back.
24x12x3 front mount
no emmisions
Microtech lt-8
720/1260s
T04e .60 .96
greddy log manifold
will be running about 15-19 psi
any info would be great. I have seen #s for a similar set up doing 403ish HP..
Would it be possible to do around 400 with this setup?
Thanks
---James
Old Feb 1, 2006 | 05:12 PM
LUPE's Avatar
Street Port
24x12x3 front mount
no emmisions
Microtech lt-8
720/1260s
T04e .60 .96
greddy log manifold
Thanks
---James
You've only got enough fuel for around 390whp.
Old Feb 1, 2006 | 05:48 PM
ronbros3's Avatar
I got same everything except 850-1600 squirts, made 410whp dynojet
Old Feb 1, 2006 | 06:06 PM
FD Rey's Avatar
I brake boost
yeah with enough fuel you can make over 400rwhp.
Old Feb 1, 2006 | 07:10 PM
red87tll's Avatar
390? humm.. guess I will start searching for some 1600s.
Old Feb 2, 2006 | 03:23 AM
bcty's Avatar
Boost This!
its not the fuel thats limiting you its the turbo at that psi 390-400rwhp seems right. you should have lots of fuel with a good regulator
Old Feb 2, 2006 | 10:50 AM
red87tll's Avatar
Originally Posted by bcty
its not the fuel thats limiting you its the turbo at that psi 390-400rwhp seems right. you should have lots of fuel with a good regulator.
One says I have enough fuel, and one says I need more boost. Battle for the correct anwser.
Old Feb 2, 2006 | 11:47 AM
RacerXtreme7's Avatar
NASA geek
Your going to run out of fuel and you'll need to run over 1 bar (14.7 psi) to reach the 400 rwhp mark (more like 18 psi). I'm assuming this is a 57 trim T04E. If its a 60 trim, making 400 whp at or close to 1 bar is possible granted all things in your system work good and are tuned but still won't be too easy. There are so may factors to ones' wheel hp numbers, like which dyno, the ambient temp and humidity, dyno opperator, wheel/tire combo, engine health, fuel used, etc etc etc etc.
~Mike..............
rgordon1979
40
Mar 15, 2022 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
