AEM EMS Area is for discussing the AEM Engine Management System!
AEM An actual good basemap for stock tt?
Old Jan 27, 2006 | 09:34 PM
point5chink's Avatar
Does one exist? People seem to complain a lot about the ones provided by aem, but most people seem to get theirs to start up and run properly after some tuning. Unfortunately, no one posts their maps after they do this. Does anyone have one or have a link to one? Thanks!
Old Feb 2, 2006 | 10:02 PM
ok, how about any base map? The ones on the forum page arent valid cal files!
Old Feb 4, 2006 | 09:24 AM
toddah's Avatar
It would be great if we could get a posting of geographical oriented base maps for stock cars that work as a startup for new tuners. If we could all learn to share info it would go along way in gaining acceptance from the tuner community and make this EMS really fly. Unfortunately most of the maps posted up to date are California based cars or are very modified cars that are great if you happen to have that list of mods on your cars.
We need to get maps that people can use to just get the cars started and begin tuning in the different areas of the country (or world). I have had my AEM serial # 0001 in and out of my car about a dozen times and still am scared to really let the boost fly with any confidence, tuners are few and faw between here in cow country (wisc). I have seriously thought many times about throwing the towel in and getting another EMS but I see the potential for this and really want to get it working. My car is a summer daily driver and I cannot afford to lose a motor so I am cowardly cautious with this thing. if I could get say a Chicago based map (proven by daily use) for a nearly stock 93 I would feel much better about tuning the car with the AEM. I have worked with MOTEC in Porsche racecars but had the motors on a bench dyno for the initial setup.
Old Feb 4, 2006 | 01:02 PM
right now i will take any base map! someone has to at least have the original basemap that is found here http://forum.aempower.com/bbs/viewtopic.php?t=4850 . The attachments on the AEM board are messed up and no one seems to be fixing them, so if someone here had the basemaps that would be awesome.
Old Feb 6, 2006 | 06:14 PM
Hyperite's Avatar
Vagina Junction
You're not really supposed to have a base map you can go cruising with... just enough to start it and get some A/F readings without the engine blowing up. The AEM base map did that just fine for me, then I tuned the **** out of it.
Old Feb 6, 2006 | 08:17 PM
the one provided doesnt even let you start the car cold without a lot more enrichment. Also, the injector phasing is completely wrong (at least according to how the help file says it should be setup). I feel like they never even tried the map provided on the CD in a real rx7 But anyhow, i did get that map started, but i also found a better map to work off of that has the injector phasing set correctly (at least better). Ill probably post it once i get home from work....or when i remember to.
Old Feb 6, 2006 | 09:19 PM
Hyperite's Avatar
Vagina Junction
Oh yeah, i forgot about the phasing, that is some bullshit.
cristoDathird
28
May 30, 2019 08:47 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
highspeedrider
Aug 19, 2015 03:44 AM
