(DRIVETRAIN) Rebuilding my GSL-SE Rear end
Old Jan 20, 2006 | 07:06 PM
cptpain's Avatar
Torqueless Wonder
recently during the drift events here in TX i have been noticing something... my lsd is going out i can barely hold a drift and when i launch the car one tire strip is longer than the other. i am planning on rebuilding my complete rear end with a new LSD. the only question is who makes one? I remember reading an article or something a while ago that a miata LSD from a certain year will fit into my pumpkin, is this true? once i get the rear end built i wanna see how much power it can handle with new ring and pinion, stronger axles, and a new LSD. i dont want to keep asking my friend to weld up open diffs or keep buying used GSL-SE lsd. any help would be great
Old Jan 20, 2006 | 08:28 PM
The 84-85 GSL rear diff is stronger than the SE. If you have both of them apart, the 3.909 ring and pinion from the GSL is considerably beefier.
Old Jan 20, 2006 | 08:38 PM
autopaul's Avatar
lightened fb
get a gsl diff like blastnisideways12a says,, or you could get a lsd rebuild kitt,, something i havent yet looked into, but i wanted to get one later in my build.. maybe someone can clarify,, while you have it out you mayaswell replace some bearings ( the side bearings can go and ruin your axles if your not careful... im going to do this before i put my car back on the road...
Paul
Old Jan 21, 2006 | 12:08 AM
cptpain's Avatar
Torqueless Wonder
i understand the whole difference between the SE and GSL rears but i dont have a GSL nor can i get one around my area. i not only drift i also road race and drag so this rear is going to be punished to within an inch of its life. right now i havent done anything abusive to the car since october because i thats when i started to feel the rear start to wear out. i appreciate your input.
I know there was somewhere i read that an aftermarket or stock LSD for a miata bolted right up to the SE pumpkin i just dont remember where. if i cant figure this out then i might as well put a ford 8.8 in an just go draggin an driftin
Old Jan 21, 2006 | 12:40 AM
vipernicus42's Avatar
Rotoholic Moderookie
Here ya go, should help you out some:
http://mrmazda.no-ip.com/interchange.html
Jon
Old Jan 21, 2006 | 12:51 AM
Expensive, but really cool diff upgrade:
http://www.gurumotorsports.com/
specifically:
http://www.xtremerotaries.com/main2/products/diff.htm
Discussed here:
https://www.rx7club.com/showthread.p...ght=miata+diff
Jon
Old Jan 21, 2006 | 01:14 AM
Check this out:
Amazing what a single search on "miata diff" brings up eh?
You can do that, but if you can't figure out the search function, are you sure you can handle a rear end swap? That last one was even in the ARCHIVE!
And some info on differentials in general, torsens, miata diffs, gear ratios and a great spreadsheet:
Jon
Edit: There's one page I just CAN'T FIND! IIRC it's a black page with green writing detailing the swap of a miata rear into an Rx7.... Anybody know where it is?
Th0m4s
Feb 26, 2019 02:04 AM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
