Canadian Forum Canadian users, post event and club info here.
paint probs....!
Old Jan 19, 2006 | 12:07 AM
ViciouS_27's Avatar
paint probs....!
i was doing a paint on the car todday....primer went on right...but when the base coat went on it was forming crystal like streaks....why is that?
what can i do?
Old Jan 19, 2006 | 07:02 AM
granto's Avatar
Is it a metallic colour you're spraying?
What temperature we're you spraying at?
Old Jan 19, 2006 | 08:39 AM
Feds's Avatar
More Mazdas than Sense
It is either:
1. Too Cold
2. Too Thick
3. Not shaken enough
Are you spraying out of a can, or out of a for-real sprayer?
Old Jan 19, 2006 | 11:14 PM
ViciouS_27's Avatar
the temp is around 30 ..
its a compressor spray
Old Jan 20, 2006 | 06:05 AM
granto's Avatar
It sounds like you need to use a faster reducer.
I'm assuming Paint Circuit supplied your paint. I'd be surprised if they didn't give you the appropriate reducer for the temperature you're spraying at.
The only other thing I can think of is your gun is set improperly. If you sprayed a high solids primer and didn't change the settings on the gun you probably have to back off on the trigger adjustment when you spray your base coat.
