Are these safe mods to reach ~210 RWHP ?
Old Jan 31, 2002 | 05:18 PM
Rx-7Addict's Avatar
Rotary Powered
I have some money to put into my Turbo II finally...
Will this be a safe list of mods to get?
Heres the mods needed
Most are for the goal of adding 60-75 HP at the crank
Also, I need a new clutch, mine slips a little, and will definantly replace before these mods
And I need a boost gauge because of FCD and want an A/F ratio to make sure I am not leaning out
With this setup I should be making 9-10 lbs of boost, correct?
-RB turbo back full exhaust system
-Apexi Power intake
-FCD
-Walbro Fuel Pump
-Bonez street/comp. clutch
-Boost gauge
-A/F ratio gauge
This is setting me back over $1500, so I need all the reccomendations I can get. This is a big investment for me! Last thing I want is to lean out the engine or too much stress on the engine or other components. I appreciate all the feedback.
Old Jan 31, 2002 | 05:22 PM
Rx-7Addict's Avatar
Rotary Powered
Also:
I am shooting for high 13s or low 14s with this setup
Possiable?
Id really like to have a 13 second car, which would mean shaving over a second off what I have now
Old Jan 31, 2002 | 05:38 PM
kabooski's Avatar
Laying Down Rotary Law
pump FPM012 - $117 http://www.autoperformanceengineering.com/
aerospeed intake less then $100
RB DP with Presilencer $245
custom single 3" pipe with a 3" Ultra flow Muffler $225
FCD $115
RPS Street/ Strip Clutch for 86-91 RX-7 Turbo $263.00 rx-store
Boost/air gauges $120
Greddy 720cc Injectors x2 -
$220 - http://www.calinetworks.net/nwimports/fuel.htm
= $1,405
add 50 or so for shipping
and you should have no trouble reaching your goals.
Old Jan 31, 2002 | 05:53 PM
kabooski's Avatar
500 more and you could go with a Haltech F9A with a 85 dist
and skip the FCD you won't need it with the Haltech
1600cc $90 each
and save $400 going with a custom exhaust instead of the RB one
and run 12's @12PSI
Old Jan 31, 2002 | 09:56 PM
Rx-7Addict's Avatar
Rotary Powered
Hmm.. that sounds tempting, but I dont know if I can afford that kind of money The car is my daily driver, and while I would love a 12 second car, I dont know if it will be financially feasable. Im 16. Maybe I could pick up a used haltec or other engine management system. I like the idea of being able to make my own maps and things like that.
However, I like the RB exhaust a lot and am likely going with that.
Either way:
Figure RB exhaust: 800
pump 120
clutch 270
gauges 120
injectors 300
haltech ~500
intake 150
im not sure if i need the intake .. it is modest gains for a lot of money, but prob. needed with 300++ hp at crank (needed for 12s)
thats almost 2300 there. I would say that is probably doable
Maybe you could give me some advice on exhaust systems. I want a reasonably priced exhaust thats affordable, not too loud, and wont drone on the highway. A full RB exhaust runs 800.
This is kind of personal, but 3 months ago I took money I had saved for over a year and bought my Turbo II. It was $2800. Right now, I have a little over 1000. In a month or 2 (by spring for sure) I could have the money for that. I will see. Thanks a lot for the advice, you really seem to know what youre talking about. And I really appreciate you trying to help me save money. My knowledge on modifing cars is very limited, my T2 is my first car.
Can anyone else reccomend a setup? I want a daily-drivable setup that is reliable and the fuel system can accomidate the power. What kabooski laid out sounds good. Kabooski: Do you have IM... hit me up: W4KE ..
Old Jan 31, 2002 | 10:08 PM
Rx-7Addict's Avatar
Rotary Powered
Ohh yea forgot to add $400 for the valentine one...
Please, I am asking anyone who has gotten their Turbo II into 13s or 12s please help me out.
Old Jan 31, 2002 | 10:23 PM
TwinCam13BT's Avatar
Whats up.
Here what I have...
87 T2
Racing beat turbo back
FCD
680cc from gsle
upgraded pump
Crap intake.
89+ 13BT
13.2 stock clutch
If you want to save money, just have your exhaust custom fabbed at an independent shop. Save you a lot, instead of buying the RB system (although its great and worth every penny).
Old Jan 31, 2002 | 10:36 PM
BLUE TII's Avatar
Rotary Motoring
Addict-while you are doing the clutch take the exhaust side off the turbo and port the wastegate. Do a forum search for the process. On the 87+88 TII the wastegates are too small and w/ free flow intake and exhaust it will cause dangerous, uncontrollable boost creep. Do this and you can run w/ unrestricted exhaust for super fast spool-up!
Old Feb 1, 2002 | 09:54 AM
Grimlock's Avatar
Thumbs up my TII
your right on the money about hitting 10 lbs. of boost. you forgot about fuel control though. your gonna need a safc to richen things up on the high end ($350 or so). get a egt gauge to so you can make sure everything is running tight. did you know that your flywheel is 28 lbs. might wanna think about swapping that heavy thing out for a light steel one at 18lbs or do like me and get a 12lbs aluminum f/w. acceleration is drastictly changed should help with that 13+ second 1/4 mile time you want.
i got my TII bone stock and the 1st things i did where:
1. the exact same exhaust you want (rb turbo back) $800.00
2. flywheel and clutch $700
the car ran fine and quick but fuel cut was biatch so if you goin that route i recommend getting the fcd and safc $450 and walbro pump $125
total = $2075.00
if i was you i'd wait until you get about $2300.00, then do all this in one shot. or do the exhaust 1st and dont boost her past 8 psi unitl you get the rest of the stuff.
toplessFC3Sman
Mar 20, 2018 01:54 PM
Snook
Oct 4, 2015 08:47 PM
localized
Sep 16, 2015 12:18 AM
