fc3s - n/a vacuum secondaries mod?
Old Jan 13, 2006 | 08:18 PM
n/a-luvr's Avatar
certified nutz and boltz
I had a quick thought today - what if we removed the main secondary throttle plates, plugged the holes, discoed the linkages and used advancing throttle body vacuum to actuate the cold-start secondary plates which would now be used as the main secondary throttle?
theoretically, depending on timing of throttle actuation, low end torque would be increased from a higher velocity intake charge at low rpm due to higher manifold vacuum. should make a N/A RX7 more "streetable" with virtually no affect on top-end response / power-band.
kinda like a carter AFB or holley with vacuum secondaries on a V-8.. It's commonly known that on street cars vacuum secondaries are ideal, especially for larger cfm carbs vs. smaller cid engines due to secondary actuation by sustainable manifold vacuum. mechanical secondaries are recommended for drag / race engines.
has anyone done this / heard of this? post you thoughts ~rich
Old Jan 26, 2006 | 10:28 AM
SirCygnus's Avatar
whats going on?
um... do it and tell us. or do it and dyno tune it.
Old Jan 26, 2006 | 07:06 PM
j9fd3s's Avatar
Community Builder
its a good idea, but the na motors already are setup for low rpm power, even a bit at the expense of top end
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
ZacMan
Sep 19, 2015 09:20 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
Frisky Arab
Sep 4, 2015 06:17 PM
