Well $h!t....need Help!!
Old Jan 31, 2002 | 10:23 AM
Well last night i took my car again to the Drags...it was a good turn out, there where 3 other second gens there. i beat 2 and was about to race the last one...we stage...light goes green and boom!!! snapped my rear end off the line....Now i need to know what years are compatible with my 86 n/a...it has a clutch master stage 3 clutch...so i got good torque hitting that rear...i once saw something about using a miata lsd...Well please let me know so i can start looking.
Buddy
Old Jan 31, 2002 | 10:35 AM
Samps's Avatar
What do you mean by "snapped"? You may have just broke the mount. How exactly did this happen? Were you dropping it at 7000 rpms? How much power you puttin down? Any nitrous?
Old Jan 31, 2002 | 10:41 AM
well
I was at the light, i launched at about 6k, and it hooked up and the the motor just started reving...i could feel something bumping when it was in gear and i let off the clutch...when the tow truck lifted the front i saw all the fluid poor out the defferintial..no i dont have nitrous...just a stage 3 clutch, straight pipe, and bad *** tires...
Old Jan 31, 2002 | 10:47 AM
rico05's Avatar
WTB S5 N/A FC
As for a rex differential, any n/a will work. If you are seroius about racing, buy a full TII drivetrain (tranny, driveshaft, rear diff, halfshafts). It is waaayyyy stronger. I saw one guy selling his for $600 bucks for everything! Or just find a wrecked GTUs, and get the LSD out of it.
Old Jan 31, 2002 | 12:17 PM
SpeedRacer's Avatar
Formula Mazda Driver
Yeah, that'll happen.
Old Jan 31, 2002 | 01:37 PM
mazdaspeed7's Avatar
mad scientist
The LSD unit from a Miata will bolt right in, and is goot for 300 hp/275 ft/lbs of torque. Should be plenty strong for a n/a engine. If you broke your ring and pinion, PM me, I have an extra 4.1 ring and pinion sitting on my desk from my wrecked 89 GTU.
BTW, Please tell me exactly what you broke when you find out. I dont want the same thing to happen to me in a couple of weeks when I get a good clutch and go to the strip.
Old Jan 31, 2002 | 02:24 PM
YO, whats up Mazdaspeed7 long time no see...well i looked under the car and the axle on the passenger side is hanging out...and the bolts are still on so the whole bolt unit came out...so what now...what year miata??
Peace
Buddy
Old Jan 31, 2002 | 02:36 PM
mad scientist
All of the miatas had an LSD *option*. Most of the 90-93 ones did not come with a LSD. After that, they LSD's came on more models standard. From 94 on, *most* of the non-base model Miatas had a LSD. Node has a more detailed list of what models came with them, etc.
Did you change your AIM SN of what? IM me, af24179 I have a diff torn completely apart, and Ill send you some pics over AIM of what it should be like.
