Rotor Weight Deviations vs. Letter Stamp
Old Jan 12, 2006 | 05:48 PM
pistonsuk's Avatar
I was wondering what weight deviations are associated with the various letters stamped on the rotors. i.e. the "A" weight rotor is 0.??lbs less than the "C" and the "E" is 0.??lbs heavier than the "C".
Thanks,
Justin
Old Jan 13, 2006 | 02:44 AM
t-von's Avatar
Rotor Head Extreme
Don't know the percentages. Just keep them within two letters of each other.
Old Jan 15, 2006 | 01:25 PM
Indian's Avatar
It wasn't me!!
mine has a S on it?
Old Jan 15, 2006 | 01:59 PM
c00lduke's Avatar
Originally Posted by Indian
mine has a S on it?
I'll I've seen have the S. There is another letter, A-E, on the gear side of the rotor.
Old Jan 19, 2006 | 08:44 AM
pistonsuk's Avatar
I have a couple FD "E" rotors and a "B". I will try to find a scale on campus and see what weights they are.
Justin
Old Jan 27, 2006 | 09:10 AM
pistonsuk's Avatar
S5/S6 rotor weights
Okay, these are the weights of 3 9.0:1 comp S5/S6 rotors that are clean, include the rotor bearings and gears and have no seals or oil control rings in them.
"B" 4377.57g (9.650lb)
"C" 4342.11g (9.573lb)
"D" 4343.67g (9.576lb)
hmmm.... not in order?
The letters listed above are from the gear side. The "C" and "D" rotors both had an "E" on the other side.
Looks like the 0.05lb I am planning on removing (beveling on the trailing edge) shouldn't be a problem for the counterweights though.
Justin
Old Jan 27, 2006 | 04:57 PM
MrRx's Avatar
Rotary on a budget
unless your rotor's are completely clean dirt, oil, other buildup would be throwing your numbers off by a little.
Old Jan 27, 2006 | 11:23 PM
Stanello's Avatar
backslash beanbagrace
Also take into consideration that all of the rotors will not have exactly the same wear on them.
Old Jan 28, 2006 | 12:02 AM
t-von's Avatar
Rotor Head Extreme
What wear are you talking about? Rotors don't make contact with the rotor housings unless something major went wrong. The only normal wear there here is the bearing wear. Is that what your talking about?
Old Jan 28, 2006 | 08:53 AM
cpa7man's Avatar
Racing is life!
http://www.mazdatrix.com/faq/rotorwgt.htm
Good general info here
Old Mar 31, 2006 | 08:38 AM
pistonsuk's Avatar
Mean Rotor Weights
BTW: Of these rotor weights posted earlier:
The last one ("D") is the S6 rotor. Maybe that explains the fact that it seems "out of order"?
Kevin at Rotary Resurrection PM'd me these "mean" rotor weights. Thanks Kevin for taking the time.
Originally Posted by RotaryResurrection
Just for you, I weighed a few s5/6 rotors while rearranging/cleaning some for the shelf.
A 9.7lb 4400g
B 9.65lb 4377g
C 9.6lb 4354g
D 9.55lb 4331g
E 9.51lb 4314g
A few of these I had more than one rotor of each letter of, and I noticed that within each letter there is still a tolerance of 0.03lb one way or another. So a C could be anywhere from about 9.58 to 9.63. As i've stated before, the letters are just a tolerance scale, and not absolute. For instance, the general rule is to stay within 1 letter when doing a build, like C and D, which should be something like 9.55 with 9.6, a variance of 0.05lb. In reality you could have a light B and a heavy D that would mate up just fine, like 9.63 and 9.57, still a tolerane of 0.05, but not within the "rule" of 1 letter.
So in summary the answer to my question:
Thanks,
Justin
It looks like there are ~23grams (0.05lb)in each letter range.
alfred1976
1st Gen General Discussion
Oct 1, 2017 09:51 PM
