Clutch Release Mechanism
Old Jan 12, 2006 | 05:59 AM
Tazzman69's Avatar
A Work In Progress
Angry Clutch Release Mechanism
Ok, so I started to pull my tranny tonight, and about two steps in discovered that the Clutch Release Mechanism on the top of the tranny is in severe disrepare. So, I stopped there and thought I should consult the experts... YOU!
I dont know if I should continue pulling the tranny if this could be the real problem.
The boot is trashed, the linkage into the CRM is so loose I can almost pull it out, and the round tip at the end mates perfectly with the clutch release on the tranny (no Pressure). Also, there appears to be some sort of air line leading out of the CRM, and it has a huge hole in it.
Call me stupid, but could this be the reason I can start the car, put it in first, let out completely on the clutch and the car goes nowhere, and the engine remains ideling?
I was told it was the clutch, but maybe the clutch is fine but this just needs to be replaced?
Any thoughts? (Code for HELLLPPPP!!!!!)
Old Jan 12, 2006 | 08:30 AM
hornbm's Avatar
FD > FB > FC
can you take pics of the clutch fork?
Old Jan 12, 2006 | 08:48 AM
kettlman's Avatar
THE ONE. THE ONLY!
i'm almost lost. whast year car? crm= slave cylander? hole? we need pics BAD! but if you can put in in 1st and still go nowhere i would still pull the tranny to look real well at whats going on.
Old Jan 12, 2006 | 09:46 AM
z-beater's Avatar
REW'd FB
crm...clutch release mechanism
Old Jan 13, 2006 | 03:28 AM
Tazzman69's Avatar
A Work In Progress
Requested Pictures
Ok, so here are a few pictures I took of the Clutch Release Cylinder, better known as the slave cylinder. (I just found this out)....
Top side:
<p>
Side View:<p>
Clutch Fork:<br>
So, with the images above, is it possible that the Clutch Release Cylinder is the probem rather than the clutch itself?
Old Jan 13, 2006 | 08:23 AM
hornbm's Avatar
FD > FB > FC
you think the slave cylinder is bad just because the boot is torn? Not likely, the boot is a protection boot. Hook the slave cylinder and get a friend to watch for slave momement when you push the clutch pedal down.
but the more I think about it, if the car is ON and you are able to shift to first, and you release the clutch and it doesnt do anything... its probably the clutch dude. The things your asking about wouldnt allow you to even get into gear in the first place
Old Jan 13, 2006 | 10:19 AM
Atkins Dan's Avatar
Former Site Sponsor
is there any brake fluid in the clutch master??? or does the clutch peddle stay to the floor when you step on it????
Dan
Old Jan 13, 2006 | 12:25 PM
KompressorLOgic's Avatar
I
i agree with hornbm , sounds like your going to have to pull the trany.. something inside is messed up
Old Jan 14, 2006 | 03:12 AM
Tazzman69's Avatar
A Work In Progress
I guess the picture doesn't show the fact that the rod is nearly falling out (whats left of the boot is the only thing keeping it attatched). However, I think your all probably right - Gonna have to tear out the tranny. But, I think i'll go ahead and replace this too, since I'm right there and the part is only $25.00 ...
Old Jan 14, 2006 | 03:27 AM
kettlman's Avatar
THE ONE. THE ONLY!
yeah. best to replace it anyways. so many times they are the problem. but to let you know. the only thing that holds that rod on is the boot/ pressure against the release fork.
Old Jan 20, 2006 | 03:51 AM
Tazzman69's Avatar
A Work In Progress
Ok, new question, same topic - I had a friend feel for movement while I pushed in on the clutch. The cylinder moves just fine, but is now pressurized, and I can't get it to go back into place. I need the rod to move into the slave cylinder about one inch, but I can't seem to do it with strenth alone. How do I release pressure from the slave cylinder? Or, is there an easier way?
Old Jan 20, 2006 | 06:44 AM
spokanerxdude's Avatar
Less Cubes, More Balls
Loosen the bleed screw on the top of the slave cyl.; do it slowly and retighten when the pressure is releaved.
Old Jan 20, 2006 | 06:54 AM
Tazzman69's Avatar
A Work In Progress
I don't think this slave has a bleed screw... Look at the pictures above. Unless you mean to disconnect the hydro line.... Thinking big mess!! Anyone have any other ideas?
Old Jan 20, 2006 | 08:45 AM
90WhiteVrt's Avatar
FC4ME
Try taking the top off the resevior then pushing the slave cylinder back in.
Old Jan 20, 2006 | 09:08 AM
The bleed screw is circled, why it has a hose pushed onto it I don't know unless someone was using it for a vacuum plug who knows. Yes it is alittle messy but something you would have to do to a new one if your still planning on replacing it. The cap on the clutch master is vented so taking it off probably won't do anything.
firzen
Sep 15, 2015 12:04 PM
