CD draining power
Old Jan 8, 2006 | 06:07 PM
hanman's Avatar
CD draining power
Ok, I finally think I have found the drain on my battery.
I looked everywhere. What was confusing me was when I put a multimeter on the battery cables I was getting a major drain. Like to the tune of 10a. I pulled every fuse and disconnected the alternator. No luck. So, starting at the beginning (the battery), I figured I would trace the wiring to the fuse box. Obviously, the drain was before that. Well I have my CD head unit wired directly from the battery. I pulled that wire off the positive cable and no more drain. I put the tester on that wire and I have the huge amp drain.
So the question is now, what could cause that kind of drain from the head unit? Could it be a weak ground. I had some problems with that when I first installed it. Or, worse, would it be in the unit itself?
Th0m4s
Feb 26, 2019 02:04 AM
alphawolff
Nov 17, 2015 05:57 PM
rotor_veux
Aug 31, 2015 07:49 PM
