PD replacement??? lost!!!
Old Jan 30, 2002 | 07:36 PM
Flinstone Power
Unhappy PD replacement??? lost!!!
I only had my rex for a month and have had a bunch of **** wrong with it.. I suspose its cuz it has 181K on it but thats besides the point.. My PD finally went bad and i am do for a replacement. i am assumming its under the upper intake right?? can you guys give me step by step instructions please... also isnt there a cheap fix like replaceing it wiht a NA fitting, banjo bolt or something.... if so what size how much will it cost and what would i have to do to fix it. Thanks for the help, Dave
P.S. dont tell me to use the search button i have and couldnt really find anything useful. Thanks
Old Jan 30, 2002 | 07:56 PM
tesla042's Avatar
http://haxx0r.net/car/rx7/pulsation.html
I found two 89+ fuel rails for under 30$ each.. used..
-Tesla
Old Jan 30, 2002 | 08:13 PM
hanman's Avatar
Yes, you can replace it with a banjo bolt. It is right under the upper intake. Trace the fuel line, it is on the end of the primary fuel rail. It's a little top hat looking thing. If you don't have a Haynes manual, go buy one.
hanman
Old Jan 30, 2002 | 09:06 PM
Flinstone Power
where and how much for the fuel rail i need to get this done asap thanks dave
Old Jan 30, 2002 | 09:30 PM
RX-7Impreza's Avatar
I am the Anti-Ch(rice)t
ok if you upgrade to a s5 fuel rail and use the bolts from your s4 you have to take nuts and thread them onto the bolts because they are too long for the smaller fuel rail. then you have to get a longer fuel line on the inlet side. that is about it for that.
it is always better to get a new fuel rail than to put a banjo bolt in it. but the bolt will work too. your choice.
Justin
Old Jan 30, 2002 | 09:44 PM
mprime's Avatar
Banjo bolt
12mmx1.25
EAR-807691
fits a AN-6 hose
Find at Summit for 16 bucks
Old Jan 30, 2002 | 09:52 PM
my motor was rebuilt before i got my car, would they have fixed the PD problem so it does not leak??
Old Jan 30, 2002 | 10:04 PM
Flinstone Power
thanks guys for the help... my motor was rebuilt and guess what???? they didnt fix it.. Thanks for the help Dave
DerpyToast
14
Nov 23, 2024 05:19 PM
Frisky Arab
Sep 4, 2015 06:17 PM
