Fuel Frig. on T.stat.
Old Jan 30, 2002 | 06:46 PM
Question Fuel Frig. on T.stat.
just reading the thread on the thermastat when I remembered a thread
long ago about a way of getting extra fuel from a mod on tep. sensor
was it any good can any one here throw some light on this one?
T.I.A
Old Jan 30, 2002 | 07:14 PM
RETed's Avatar
What you're doing is adjusting the coolant thermo sensor so that the ECU thinks the coolant/engine is a bit cooler than it is - cooler coolant/engines temps wouldd trigger a richer mixture.
The problem is that the hack just included a pot that's in series with the stock OEM coolant thermo sensor.&nbsp This means you'll need to mess with the **** constantly to adjust mixtures - WOT versus idle.&nbsp This can easily be fixed by using a pressure switch that would change the mixture only when above x amount of boost.
-Ted
rgordon1979
40
Mar 15, 2022 12:04 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
sherff
Sep 12, 2015 12:22 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
