Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D Auto tuner in progress
Old Jan 3, 2006 | 09:29 PM
Michael Smith's Avatar
Ok I have started planning the inital phases of a Auto tuner for the wolf based on my Wolf logger.
Cheers
Old Jan 3, 2006 | 11:08 PM
signofinfinity's Avatar
Coyote
2006 project..... am sure it will be a success like the logger!!!! good luck!!
G
Old Jan 9, 2006 | 02:36 PM
teknics's Avatar
hey michael, interesting program idea, let me know if you need help, i got that vb 2005 installed, seems to be a pretty nice package compared to vb6.
let me know,
kevin.
Old Jan 10, 2006 | 07:29 AM
Talking
let me know,
kevin.
Hi Kevin, the biggest single problem is building the fuel table from the logon data and then rewriting the data back to the ecu on the fly. I have not started the code yet but have layed out how I will approach the program.
I will install VB2005 on my Workshop computer when I upgrade it to XP Pro it is currently Win 98. I have lots of programs I have written in VB6 that I would like to migrate to VB2005 but have not enough time to do that yet. I will look at putting XPpro on my Workshop as long as my video monitoring software/hardware still works.
Regards
Michael Smith
Old Jan 10, 2006 | 02:47 PM
teknics's Avatar
writing on the fly i would picture being one of the bigger problems, the wolf's capable of reading a changing map on the fly (havent got mine installed yet, still waiting to rebuild my engine, god im lazy)
but anywho its a great thing to have you as a wolf user, youre very helpful to everyone, and apparently much better then AEM is lol.
kevin.
Old Jan 15, 2006 | 06:10 AM
Talking
Hi RotorMotor2, I will have finish hacking the logger this week and remove all the little bits I was using to decode unknown data. I think you will be happy
I am still wanting to see the New Wolf software though, I think I get more accurate info from it as well!
Cheers
Michael Smith
Old Jan 15, 2006 | 08:50 AM
Coyote
Cheers
Michael Smith
Hi George,
Getting closer. Just a couple of things to
finish up. About 2 weeks to go. Around the end of
the month.
Best regards,
Steve..
Steve Taylor
Advanced Engine Management Pty Ltd.
22 Melrich Road Tech Phone: + 61 3 9761 3609
Bayswater, Victoria Fax: + 61 3 9761 3162
Australia 3153 Email: steve@wolfems.com.au
PO Box 594, Bayswater, VIC 3153 http://www.wolfems.com.au/
I keep bragging Steve for it..... his reply!!
Old Jan 16, 2006 | 02:18 AM
Coyote
Originally Posted by RotorMotor2
george 2 weeks said that email? dont get me excited,...... myself along with many others have been waiting how long?, like a year or more with false promises of new software and no results? i see no news of this on their website.... come to think of this, i have never seen a change to their website........... to be continued......
Yeh Jeremy..... I am quoting Steve in AU! end of january is the release date............. thats all i can say, coz that is all i know. I was told to tell you guys that it will be out. It was going for 'a beta' release end this month.
I dont think that steve will say something out of thin air. I am confident that by February we will be running the software! with michael's innovative auto tuner.... the wolf will be a biggggggg Hhhittttttttt!!!
I look forward for it as much as you guy are!! RLC.... what have you to say on the topic?
RLC should have info from the drawing board.... i hope..
Regards
George
Old Jan 16, 2006 | 07:44 AM
OK the basic plan is made on scraps of paper and cardboard cheese ring box (sounds like I am building a space ship where the bloody tape and Q straps)because I didn't have any paper when the ideas came. Basically this is how it will work .... I think you would like this idea RotorMotor2.....it will have Min rpm, Max Rpm then for each load point you can set the voltage target. If it sees the accellerator pump in action or the tps varies by more that 3% or the tps goes to less than 2% it will not do anything. If the TPS is stable and the Accell pump is not working and within the target rpm range it will attempt to tune to you Voltage at that load. If it is lean it will add 10 Hex(adjustable) to richen it up quickly and if rich will take 2 hex off if it is more than 0.04 Volts above the target Voltage and 1 Hex if it is 0.02 Volts above target. Once the target Voltage has been met that point will be locked for 10 samples to determine if it needs to go a little leaner.
It will also only work with the motor above 85C (open to suggetsions here).
I have moved some files across readly for the assult and Named it Wolf Autotune.
Ideas anyone????
Michael Smith
Wolf V4
Old Jan 17, 2006 | 04:55 AM
Coyote
Why not reduce the tempreture to 80 deg c and above? I mean normal ops temp is above 80degC.... and each car varies..... like on idle after a long run my running water temp drops to 78-82 degC......
Rgrds
G
Old Jan 17, 2006 | 06:25 AM
OK it is not too hard to give a range from say 75 - 99 C user selectable.
Any other suggestions??? Also with the Auto tuner you will have Calibration file for the AFR reading as to allow for Narrow and wide band sensors but the guts of the tuner will not be AFR but the output VOLTAGE, the AFR is only there to keep a eye on it. I have put together the last version of Wolf Logger but I am yet to test it(until the latest version of Wolf software comes out that is, their may be some good info in the new version). When I am happy with it I will release it on my software page and let you all know.
Cheers
Michael Smith
Old Jan 18, 2006 | 07:10 AM
Wolf Logger + + + + + ==Auto Tuner
Wrote some code tonight for the layout of the Auto Tuner it will log like the logger does it will also output a list of changed cells with before and after this will be a separte log. It has a big red button that goes green when the Tuner is in action actually tuning. A box to see what it is changing and well who really knows what else I will add. You still have the AFR display too! ETA? when the beer runs out maybe?
It also has fuzzy logic control too, the beers do that!!!!
Cheers
Michael Smith
Old Jan 19, 2006 | 05:25 AM
Talking
RotorMotor2 the single biggest problem is that the Wolf is too slow to give me data back. If newer versions of the wolf supported a "Knock Sensor" or we could make a interface that would work with the standard S4 /S5 sensor and output a analog voltage to the Wolf via a Aux input to retard the timing. George and I had discussed this before. Maybe we could later work on a serial port Knock sensor that uses a S4 conditioner and a small Micro processor to output data stream to a second port and get some software to read that too! 2 ports...one to the Wolf (Auto tuner)the other to the Knock detector..
Head spinning here I will grab another UDL to spin it the other way!!!!
Fuzzy logic just means that it makes its own decision on what to do just like humans do but on a much lower level. ( much like someone who is drunk)
For the moment I can only do fuel and people will still need to Dyno to get the timing bit
Michael Smith
Old Jan 19, 2006 | 07:07 AM
Ok added a configuration file to the Auto Tuner so that the settings you close your program on are saved..if it works ok I will add it to the logger as it is a pain to have to keep selecting the com port every time. I didn't do it before becasue it was too much effort for little gain but the auto tuner has heaps of settings so it now becomes worthwhile. Once working I will strip it down for the logger!!!
Cheers
Michael Smith
Old Jan 26, 2006 | 06:47 AM
Talking
OK I have decoded the fuel data map and how it is loaded into the laptop. I have decoded how it writes the data to a specific map point. I have rearranged the layout too!
Cheers
Michael Smith
Old Jan 26, 2006 | 02:02 PM
teknics's Avatar
gooooooooooo michael!
kevin.
Old Jan 27, 2006 | 03:05 AM
Coyote
woho michael..... run man!!!!
George
Old Jan 27, 2006 | 08:16 AM
The Save configuration works. Moving along...
Cheers
Michael Smith
Old Jan 29, 2006 | 06:32 AM
I should have a test run this week without it adjusting the wolf to see if it picks the right points to tune first. I will get it to spit out a list of points to change before I trash my good map. It looks different to the logger but still has all the key features.
Cheers
Michael Smith
Old Jan 29, 2006 | 03:31 PM
teknics's Avatar
awesome hopefully itll be done around the time i get my whole setup dropped into my 7, woo. then i cant at least get it tuned enough to drive 2 hours to my tuner.
kevin.
