Euegene Machanics
Old Jan 1, 2006 | 09:48 PM
actionhank's Avatar
Euegene Machanics
I will probably need a place to take my car. Last night the water pump belt broke and Im thinking it took the alternator with it. Just in case it did, anyone have a good place to take my car? Im on Barger road near beltline if that helps.
Thank you and yell at me if you want more info.
Old Jan 2, 2006 | 12:16 AM
The Spyder's Avatar
Never give up!
Bring it up here, I cant recommend a single mechanic down there for rotaries.
Did the car overheart?
Old Jan 2, 2006 | 11:21 AM
actionhank's Avatar
No it didnt. I just dont want to have to tow it up to portland if I can avoid it. I dont think Ill need a rotary mechanic, just a good machanic in case I need a alternator replaced or something.
Old Jan 2, 2006 | 06:29 PM
turbojeff's Avatar
Do it right, do it once
I'm in Eugene and I've got a lot of experience with FDs. I'm only a about 5miles from Barger.
Old Jan 3, 2006 | 05:07 AM
actionhank's Avatar
Thank you very much Jeff. I got it handled though. I still cant find a belt that freaking fits though. If you would like to come over and help out, that would be great because I would like to meet you, but if your busy or otherwise, I understand. I should have it up and running assuming I get a belt that fits.
Thank you all for your help
Old Jan 3, 2006 | 08:02 PM
Matt22's Avatar
Fear The RE
are you kidding?
your in corvalis, GO to JiJoes and ask them for both the alt belt and air pump belt
or if you have the twim alt pully two alt belts. if so look at both and make sure they are damn near the same size. then put both on at the same time, pull your alt away to tension
the belts and tighten the top alt nut, then the other nut. DONE> follow similar steps if you still have your airpump. you can do it yourself.
Come to think of it, is that my old car. if so PM me and let me know how it is. Lates Matt
damn you shodl have given me a call lol. Lates Matt
Old Jan 4, 2006 | 12:48 AM
turbojeff's Avatar
No problem, PM me sometime when you have some time and we can meet up.
Monster Driver
Comments and Suggestions Archive
Feb 18, 2010 12:36 AM
19-r-e-d-79
NE RX-7 Forum
Mar 16, 2008 06:30 PM
rotormind
Nov 2, 2007 01:44 PM
DangerousCrew RX-7
Mar 8, 2007 08:19 AM
shnakey
Canadian Forum
Jul 22, 2006 10:49 PM
