its all about the numbers
Old Dec 27, 2005 | 06:24 PM
13bturbo2's Avatar
just wondering, how much hp should i be putting down with the following also a quarter mile time:
- T-66 Turbonetics Turbo
- Greddy front mount
- 800cc secondaries
- HKS Megaflow Intake
- 3" DP with 3" full exhaust
- SAFC
- Profec B set at 12 psi *can i run more?*
- MSD Ignition
Old Dec 27, 2005 | 06:40 PM
88t2romad's Avatar
(_8(|)
800cc secondaries?? With a t66 id definatly consider bigger ones. And id ditch that safc for a stabdalone.
As for power id shoot for no more than 230 whp( its capable of more, but restricted by the ecu/injectors)
And maybe 13s?
Old Dec 27, 2005 | 06:48 PM
13bturbo2's Avatar
hmm, yeah i was thinking of a haltech and 1600cc secondaries.
Old Dec 27, 2005 | 06:50 PM
88t2romad's Avatar
(_8(|)
thats what id definatly go for before doing anything that might cause you to lose some seals.
Old Dec 27, 2005 | 06:56 PM
powrdby13B's Avatar
i'll blow YOUR valve off
i see no mention of primaries.. I'd go for 1600's all around and run that bitch 12:1 through the whole range.
You could probably hit 25 lbs of boost if you wanted.. but the engine might not like that.. I've seen people run 18-21 safely thow..
Also, if you dont have one, get a cone filter.
Old Dec 27, 2005 | 07:18 PM
slpin's Avatar
7th Heaven
12:1 at 25lbs?
hahahhahahah
way to give advices
Old Dec 27, 2005 | 07:20 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
No offense but I dont think you'd make it to the end of the 1/4 mile with that fuel setup and engine management.
Old Dec 28, 2005 | 05:46 AM
RETed's Avatar
Just 800's in the secondaries will allow you to go up to about 260hp safely, without any bump in fuel pressure - not possible with stock fuel pump.
Since you didn't mention upgrading the stock fuel pump, the stock fuel pump can barely support 250.
550's + 1600's will go up to 430...maybe 450, if you got the fuel (pump) to support it.
The T66 is good for 500hp easy.
-Ted
Old Dec 30, 2005 | 07:16 PM
13bturbo2's Avatar
i never saw the need to mention the upgraded pump though i mean it is a basic upgrade once you up the ante on any TII.
Old Dec 30, 2005 | 07:40 PM
Sideways7's Avatar
From what I've seen, its kinda implied that you need to upgrade the pump when adding any power to a T-II, let alone the kind you can put down with that turbo.
Old Jan 4, 2006 | 08:55 PM
fstrnyou's Avatar
I know a guy that dyno'd his TII to 274whp with 550/1000 injectors. and the secondaries were only at 70%DC. I'm not sure what his A/F #'s were tho. That was with the stock turbo(10psi) and a FMIC.
Old Jan 5, 2006 | 02:50 AM
RETed's Avatar
Bullshit.
-Ted
Old Jan 5, 2006 | 04:16 AM
FB II's Avatar
Originally Posted by RETed
Bullshit.
-Ted
i agree
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
