Need Info On Injectors
Old Dec 25, 2005 | 03:40 PM
12akid's Avatar
would 3gen 960cc injectors work on a my tII secondaries
Old Dec 25, 2005 | 07:09 PM
stacher's Avatar
I know that, FD injectors are "side feed" and FC are "top Feed". So...I would say no, unless you get a different fuel rail.
Old Dec 26, 2005 | 02:21 AM
12akid's Avatar
thanks
Old Dec 26, 2005 | 12:47 PM
Nismo Convert86's Avatar
400WHP or bust
Only the primaries on the 3rd gen are side feed, the secondaries are top feed. If you have a S5 TII they should drop right in.
Old Dec 26, 2005 | 02:31 PM
12akid's Avatar
would it work with a s5 fuel rail on a s4 with 3gen injectors lol
Old Dec 26, 2005 | 02:43 PM
RexRyder's Avatar
All stock FD injectors are SIDE FEED. Primaries are 550cc, secondaries are 850cc.
so it will not work with the stock Tii fuel rail.
Old Dec 26, 2005 | 04:38 PM
Digi7ech's Avatar
I break Diff mounts
^yup
You need to look for common TOPFEED injectors.
Common swaps are 720cc's
S4/S5 fuel rails swap fine. I think on mine I needed a washer as a spacer but that may have been due to the bolts length and not manifold/injector height.
If you have a S4 then you may want to look into the Rtek ECU upgrade which will allow you to use 720's without redoing your fuel system(SAFC/Haltech/etc...)
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
ZacMan
Sep 19, 2015 09:20 PM
