high surging idle, TPS issues
Old Dec 25, 2005 | 12:50 PM
Valkyrie's Avatar
Alrighty... I got my car running, and it's got a nasty surging idle (minus the clouds of white coolant smoke... I'll get to fixing that once I can borrow a cherry picker)...
I know this is normally caused by the TPS, so I tried testing both sensors with a DMM, and while the overall range, including the top is fine, idle is at 1.45-1.50 on the wide range sensor, and 1.12 or so on the narrow sensor, when they're both supposed to be 1 and .8~ respectively.
I already adjusted the crap out of it and it wouldn't get any better than what I told you it is... although I did get the idle down from 2000 to 1500... but the screw won't go any lower...
So what should I do? Replace the TPS? Or try something else?
Old Dec 25, 2005 | 12:54 PM
Dcrasta's Avatar
thermowax in the car? sounds like the thermowax idle screw is out too far, or the throttle plate stop screw is in too far..
Old Dec 25, 2005 | 01:35 PM
Valkyrie's Avatar
Well I think the throttle plate stop isn't the problem since at one point it did actually idle at 750.... and then shot straight up to 1000, 1500, and then 2000.
There is one vacuum hose I can see that's very (can be removed easily) but I don't know if it's leaking...
I suppose it could also be the coolant leak itself causing the high idle... but I think it's the TPS. I can't afford to buy a new TPS though! Unless some place sells cheaper rebuilds or there's someone with a decent used one...
Microtech
30
Apr 23, 2016 06:37 PM
rotor_veux
Aug 23, 2015 09:06 PM
sYnth.
Aug 17, 2015 07:28 PM
ncds_fc
Aug 15, 2015 10:06 AM
rkhanso
Aug 13, 2015 11:40 AM
