Megasquirt stock cranking map + cranking rpm
Old Dec 21, 2005 | 04:40 PM
slpin's Avatar
7th Heaven
stock cranking rpm is set at 470rpm
attached is stock cranking map for 2x460cc
though you guys might find it interesting!
Old Dec 21, 2005 | 06:20 PM
Rex4Life's Avatar
RX-7 Alumni
Hey that's good stuff. Thanks.
Should be no problem to scale that value for different size injectors.
Just a note they seem a little high but I bet they work. I'm using 7.4 ms @ 80 F and 4.6 ms > 160 F.
Old Dec 21, 2005 | 10:21 PM
muythaibxr's Avatar
MegaSquirt Mod
no wonder the engine floods so easily on the stock ecu... it's injecting more fuel than the megasquirt is even capable of injecting (25.5ms) at lower temps...
The engine fires up just fine with a lot less fuel than they give it... I also have a 13ms priming pulse too though.
C. Ludwig
Jan 30, 2019 06:31 AM
Microtech
30
Apr 23, 2016 06:37 PM
Microtech
Aug 23, 2015 11:04 AM
