Rear Hatch Drain Clogged, Solutions?
Old Jan 29, 2002 | 03:00 AM
DC350's Avatar
Rotor Head
This sounds really dumb askin this question....how to unplug it? Well if you've had this problem lemme know...and whats a good way to drain it? i have already stuck screw drivers down blasted water..almost ruined speakers....hehe...but yeah.any ideas?
Old Jan 29, 2002 | 03:01 AM
DC350's Avatar
Rotor Head
please
Old Jan 29, 2002 | 03:02 AM
SonicRaT's Avatar
Super Raterhater
try some draino? It might eat paint, so maybe that's not a good idea, but it might work, you never know!
Old Jan 29, 2002 | 03:04 AM
DC350's Avatar
Rotor Head
i just got 'ol rex painted as well! but it'll be worth it....cause it clogs up and pours over the side...so i have all this **** on the side of the car in the morn!
breesej's Avatar
Amish Gangsta
wire coat hanger? works for me all the time
Old Jan 29, 2002 | 04:53 AM
Chris81's Avatar
I just used a screwdriver
Beware, on mine the green goo that came out the bottom was quite sickening
Old Jan 29, 2002 | 05:51 AM
if you pull the carpet back, there is a clear tube that runs straight down from the hole, im pretty sure u can remove it and replace or clean it out.
Old Jan 29, 2002 | 07:21 AM
Mykl's Avatar
Yeah, what FoXX said.
Pull the carpet back, remove the plastic tubes, and clean them out with a coat hanger or something. Works like a charm. Then when you're done just put 'em back in. Viola, no more water puddles on your car.
Old Jan 29, 2002 | 07:49 AM
vnova94's Avatar
Don't remove anything...... simply get a coat hanger and fish it down from the top, through the tube and all the way down to the bottom...... give it a few rotations to clean out everything, and you're done. Works like a charm for me.
Matt
Old Jan 29, 2002 | 09:34 AM
Snrub's Avatar
Mine was unclogged with compressed air. Probably any place with pnumatic (sp?) tools will be able to do this for you.
Old Jan 29, 2002 | 11:09 AM
Felix Wankel's Avatar
Super Newbie
Straighten a coat hanger and stuff it throught the tube carefully. Then use a water hose to flush it out.
Old Jan 29, 2002 | 01:48 PM
Salguod's Avatar
Draino Thats just too funny... Hey I'll bet if you take a .22 cal pistol and fire a few rounds down the hole, that might work too!!!!!
Old Jan 29, 2002 | 02:01 PM
Scott 89t2's Avatar
SOLD THE RX-7!
don't use compressed air, you might just blow the tube right off it's connection. I just stick some spare speaker wire down there untill you can see it hanging under the bumber.
Old Jan 29, 2002 | 02:03 PM
Scott 89t2's Avatar
SOLD THE RX-7!
don't forget to clean out the gas tank filler tube while you'll at it
Old Jan 29, 2002 | 03:08 PM
FPrep2ndGenRX7's Avatar
Try a gun cleaning rod with a nylon brush on the end.
Old Jan 29, 2002 | 04:40 PM
yamatokh's Avatar
I used the glue stick that for hot glue gun. 10 cent a piece, just buy 2 (long one, about 10-12"), the radious fits perfect, just stick one in, push it all the way, and use the second one to push the first one. As the second one goes half way, the first glue stick should stick out from the buttom of the tube. Works great!
now the question, how do you unclog the sunroof drainage tube? I used draino last night, worked, but not very clean as water drain slowly compare to the other side. I might need to use a lot of water to flash it out or something, oh well.
any better ideas?
Old Jan 29, 2002 | 08:36 PM
Jerk_Racer's Avatar
How can I tell if my gas tank filler tube needs to be cleaned? It's very dark inside of it. I know! I'll use a lighter to see down it.
::please accept my nomination for the Darwin Award on my behalf::
Old Jan 29, 2002 | 09:43 PM
Wankel7's Avatar
Haven't we ALL heard this
But if a screw is in there going down is not the way. Why not just crawl under the car and find the point where the tube comes out and go up with a hanger or compressed air?
James
Old Jan 29, 2002 | 10:35 PM
Super Newbie
James
Cause then you get **** all in the trunk, and then get to clean the carpet.
Old Jan 29, 2002 | 10:58 PM
TonyTurboII's Avatar
Glock Lover
Check to make sure it isnt kinked. I had a problem with one of my hatch drains not draining. I pulled back the carpet, and it was kinked. The biggest bitch was putting it back in the hole through the floor! Check this out quick, cause if you dont water might build up in the panels.
Old Jan 29, 2002 | 11:01 PM
BhamBill's Avatar
I used a piece of #10 wire with a loop bent in the end. The plastic insulation keeps it from scratching. Cleaned it right out.
Old Jan 29, 2002 | 11:35 PM
fc3s94509's Avatar
i just replaced those drain tubes, it seems that somebody used a hanger and put a hole in the tube.
