My car is starting hard!
Old Jan 28, 2002 | 08:26 PM
TheTwinTurboRX-7's Avatar
Unhappy My car is starting hard!
It turns over very hard the first few turns then gains momentum and turns over faster and then starts up. What might be causing this? I cleaned both my battery terminals, but I did not re-tighten them with a ratchet. Why is my car starting hard. I am starting to get worried, and I don't want to be, so can someone tell me what this might be?
Old Jan 28, 2002 | 08:55 PM
NZConvertible's Avatar
I'm a boost creep...
I have exactly the same problem. It always starts but it doesn't sound right. Strangely it only started doing it when I replaced a small, nearly-dead battery with the biggest, baddest one I could fit in the box. I've been told I might have pushed a maginal starter motor a bit closer to death. Anybody else had this problem?
Old Jan 28, 2002 | 09:12 PM
fc3s94509's Avatar
i had the same problem, my fix was to install more ground straps from body to motor
Old Jan 28, 2002 | 09:27 PM
Unhappy
Please guys, I really need to know what might be wrong. Hope this isn't something serious!!
Ben
Old Jan 28, 2002 | 09:42 PM
Six Rotors's Avatar
If your battery is good(have it tested if you are not sure),and all the connections are good(ground to motor,power to starter terminal)then it can only be the starter motor.In many cases it is just the brushes which are worn and you can by a new bush yoke from Mazda for about $10 and install it in about 45mins including pulling the starter and replacig it.(Remember to disconnect the battery before you start)
Old Jan 28, 2002 | 10:09 PM
Cool
Cool, thanks a lot for the information guys. I will check that. Anyone have any other ideas while I am working on it?
Ben
alphawolff
Nov 17, 2015 05:57 PM
gtcd
30
Aug 19, 2015 02:44 AM
ashleymiche
Aug 14, 2015 12:59 PM
