Nitrous car vid. Got nitrous experience? Please post here.
Old Dec 12, 2005 | 10:07 AM
Doc Holiday's Avatar
Needs more cow bell
Here is a PR vid of a nitrous car. He does his burnout, then goes to launch. You see him bounce it off the limiter, then the car backfires through the carb (carb?injection? I dont know, we'll just say carb). It looks like a nitous back fire through the carb, but its not nearly as violent as nitrous backfires I've seen before. Perhaps its because the car isnt moving so the engine isnt loaded. Who knows, thats why I made this thread. If it is a nitrous backfire, does that mean the PR guys are banging the car on the limiter while on the nitrous just before they launch the car? Every PR nitrous car does this. Seems to be the popular thing to do.
If it is a nitous backfire, what is causing the backfire?
Here is the video. http://68.178.140.70/videos/009-019.wmv
Old Dec 13, 2005 | 09:01 PM
Needs more cow bell
No one has any responses to this?
Old Dec 21, 2005 | 09:20 AM
Needs more cow bell
I thought I would bring this to the top one more time to see if anyone can comment.
Old Dec 21, 2005 | 12:56 PM
SureShot's Avatar
Seduced by the DARK SIDE
Look at the end of the burn out. He had a fuel fire flash then.
I suspect he simply had a fuel line pop off.
Old Dec 21, 2005 | 02:08 PM
Needs more cow bell
Any other opinions?
Old Dec 25, 2005 | 03:28 PM
Judge Ito's Avatar
Josh.. they are bouncing the engine off the rev limiter before they launch. They are doing this with nitrous ON. While the engine bounces off the rev limiter, the micro switch is activating the nitrous.
The backfires could be a lean mixture from the rev limiting itself. scary I don't like bouncing the engine off the limiter while the nitrous is being pumped into the engine..
Old Dec 25, 2005 | 08:25 PM
Alex Rodriguez's Avatar
MODERATOR
Veteran: Marine Corp
it just happens all it is fuel backfire the high rev take off is just because they use airshifted tranny so at high rpms the rotary grips better in high than in low and its funny because it should be the other way around...just my help
Old Dec 26, 2005 | 09:51 AM
Needs more cow bell
Thanks guys. I've noticed that 99% of the PR cars slam the engine against the limiter with the nitrous on before they leave. I was curious as to why they do this. It seems like it would be smarter to put the nitrous switch on the clutch. You would still be leaving under full power off the line, and it seems like it would be easier on the clutch. Who knows, they are all a lot faster than me.
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
bb6guy
Aug 12, 2015 03:29 PM
