Haltech USB -->Serial w/ xp...i almost got it?
Old Dec 10, 2005 | 08:17 AM
Wankel7's Avatar
Haven't we ALL heard this
Cool USB -->Serial w/ xp...i almost got it?
This is on my Sony Vaio laptop. With XP.
I have had a little luck or at least progress with one USB-->Serial cable.
http://www.iogear.com/main.php?loc=product&Item=GUC232A
At Walmart for $23.
It lets you go to system and hardware manager and assign it a comm port. So, now when you open the haltech software it does not give you the comm 1 error. Now, when I try to go online with the Haltech it was loading super slow. Like, loading the haltech might take five minutes. However, it is closer than I have ever been. But then it just breaks the connection.
Any idea why it is so slow and breaks the connection? I tried running the same situation with Dosbox and it didnt even smell the haltech.
James
Old Dec 10, 2005 | 11:39 PM
lovintha7's Avatar
Suicidal Death Missile
I'm not sure about the answer, but I'm about to do EXACTLY this on mine.
Old Dec 11, 2005 | 12:52 AM
MrRx's Avatar
Rotary on a budget
check and see if there is a timeout setting.
Old Dec 13, 2005 | 03:33 AM
r0gu3's Avatar
Boostless FD
I couldn't get that to work with a friends E6K but that is how I access my E11v2. As far as not seeing it in DOS, that is due to the fact that DOS doesn't have USB support.
Old Dec 13, 2005 | 10:11 AM
Wankel7's Avatar
That is the the thing...I COULD get it to see it in dos. It reported the version/firmware numbers and started loading the Haltech then it stopped....
James
Old Dec 13, 2005 | 10:55 AM
snowball's Avatar
I live in the lounge...
they key with converters is to make shure their are set up as the com port your ECU reads.
Old Dec 13, 2005 | 11:23 AM
dscsk8er55's Avatar
rx7less right now
I used that connector allot (not for ECU stuff but cellphones) and it doesn't work with all things (computers or periphials) Do you have access to a laptop with a serial port? Sometimes that is what it takes to access certain serial periphials.
Old Dec 13, 2005 | 11:30 AM
Wankel7's Avatar
Snowball - Yeah, I did - Set it to Comm one in system
DSCSK8er55 - I do now http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWA:IT
James
Old Dec 13, 2005 | 11:42 AM
dscsk8er55's Avatar
rx7less right now
AWESOME!!! Good choice. When I was working with cell phones, the only computers that worked all the time were the older laptops. Good luck james!!!
Old Dec 16, 2005 | 11:10 AM
nik's Avatar
nik
James
I had similar problems when trying to use the Belkin adapter with e6x/halwinX. It would load firwmware to 99% then stay there forever. Never would it say "Haltech connected"
Turns out drivers for this particular one are very poor. Switched to a radio shack one and it works flawlessly.
Old Dec 17, 2005 | 12:43 AM
Wankel7's Avatar
Hummmm intresting...
befarrer
15
May 19, 2022 10:44 PM
