Are these 160lb/1680cc injectors?
Old Dec 6, 2005 | 11:24 PM
EFINI_RX-7_RZ's Avatar
Just received these injectors. Vendor advertises them as "Ford Motorsport 160#" injectors. selling them at $55 per. Came as you see them on the pic, with no caps, haphazardly black spray painted metal bodies hand scripted 1947183 on one injector and 1327183 on the other using a Dremmel tool or something. Very faint smell of WD40 on feed side, top o-ring is neon yellow, along with its pintle cap, lower o-ring bright blue with a school bus yellow plastic spacer on top. Numbers cast on the pale blue plastic body are:
On one side:
On electric plug: 927
Bosch logo, then 083, and below them: 0 280 150 843
On the other side:
On the electric plugh: + sign
Chrysler logo, then 130, and below them: 53030518AB
Searched these numbers on Google, NAPAonline and on the forum, got no matches anywhere. Can anybody confirm me that these are indeed 160lb/1680cc injectors? Do you think the Dremmel scripting means they are reman or something?
Attached Thumbnails Are these 160lb/1680cc injectors?-img_1574.jpg
Old Dec 18, 2005 | 11:42 AM
Bi-State Auto's Avatar
best person
The price seems right for the 1600's. A lot of companies for some reason remove the oem numbers. Maybe try www.fiveomotorsports.com to get info. good luck.
Old Dec 18, 2005 | 01:05 PM
Thanks. It has been all sorted out with the vendor already, they are indeed new 160lb injectors, and flowed by Precision Turbo to booth! Here is the follow-up on this thread:
https://www.rx7club.com/single-turbo-rx-7s-23/these-160lb-1680cc-injectors-488798/
and some more rantings from me here:
https://www.rx7club.com/single-turbo-rx-7s-23/bosch-1680cc-160lb-injectors-part-numbers-scramble-489123/
Old Dec 19, 2005 | 01:00 AM
diabolical1's Avatar
slightly off topic, but slightly related ...
is there a formula that one could use to convert lb/hr to cc's and vice versa
Old Dec 19, 2005 | 10:48 AM
1 lb of gas = 10.5cc of gas. At least that's how a 160lb injector comes out to be a 1680cc injector.
Old Dec 19, 2005 | 04:44 PM
calculon's Avatar
On flats
for what it's worth, they look just like my 1680s which came new in box
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
connerfd3s
Sep 19, 2015 05:58 PM
