Are these 160lb/1680cc injectors?
Just received these injectors. Vendor advertises them as "Ford Motorsport 160#" injectors. selling them at $55 per. Came as you see them on the pic, with no caps, haphazardly black spray painted metal bodies hand scripted 1947183 on one injector and 1327183 on the other using a Dremmel tool or something. Very faint smell of WD40 on feed side, top o-ring is neon yellow, along with its pintle cap, lower o-ring bright blue with a school bus yellow plastic spacer on top. Numbers cast on the pale blue plastic body are:
On one side:
On electric plug: 927
Bosch logo, then 083, and below them: 0 280 150 843
On the other side:
On the electric plugh: + sign
Chrysler logo, then 130, and below them: 53030518AB
Searched these numbers on Google, NAPAonline and on the forum, got no matches anywhere. Can anybody confirm me that these are indeed 160lb/1680cc injectors? Do you think the Dremmel scripting means they are reman or something?
On one side:
On the other side:
I bought mine from http://www.fiveomotorsport.com/Injec...ODS.asp#cngrec
$105 for the pair.
1600cc Bosch Injectors
0280150839-Aqua Top
They came exactly like this
$105 for the pair.
0280150839-Aqua Top
So, after contacting the vendor and some further investigation, here is the final word on the injectors I received:
[QUOTE]The injectors that you have are 160lb. injectors that were flowed back
on 7/18/03. At that time one of them flowed 141.2 at 18ms and the other flowed
142.8 at 18ms (which is roughly 90% duty cycle). We are now using different
o-rings than those, but am unaware of any problems that people may or may not
have had with them.
The 160lb. injectors that are currently in our bins carry a Bosch part number of
280150842. Part of this change came as we had to switch suppliers within the
last couple years. The 160's come in flowing anywhere from 160 to 165lb and
therefore we never switched the name of them.
Thank you,
Brian
Precision Turbo and Engine
> To: sales@precisionturbo.net
> Dear Sir,
> I just bought a pair of fuel injectors from Mike Lee at Race Proven Motors,
> Inc. of Chatsworth, CA. I was expecting to receive the widely known Bosch
> part # 0 280 150 846 160lb injectors original on Fords, as there is a
> picture of one of these injectors on the vendor's webstore page were they
> are described as "Ford Motorsport 160# fuel injector", instead I got Bosch
> part # 0 280 150 843, which have a Chrysler logo and part # 53030518AB
> embossed on them. These came scribed with the numbers 1327183 on one
> injector and 1947183 on the other, etched on their bodies with a Dremmel
> tool of sorts. I e-mailed Mike Lee about this discrepancy, as I was afraid
> that he had sent me the wrong injectors, and he gave me back this reply:
> "the injectors came from PTE flow matched @ 165#/hr and retail for $90ea. I
> usually sell the ford 160's but they have been backordered from all major
> distributors for the last month or so.
> Mike Lee
> Race Proven Motors, Inc
> http://www.raceprovenmotors.com
> 818-201-5352 orders"
> I will like to check on the veracity of these statements with you. If they
> are true, then I will also like to know if these two units, 1947183 and
> 1327183, are correctly flow matched, if they are brand new parts or
> remanufactured ones and if you advise on using their factory O-rings, which
> I have read that are not suitable for gasoline, as they were originally ment
> to work with CNG. Also, you will find attached below this message a picture
> of the injectors I received. Thank you.[QUOTE]
So, I indeed received 160# flow matched new injectors, and at the same time learned about a new part # for them. You can get them at $55 per plus shipping at www.raceprovenmotors.com at their sales page.
have had with them.
Thank you,
Brian
> Dear Sir,
> Mike Lee
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
