Stock vs Hybrid : pics
Old Jan 27, 2002 | 06:28 PM
Chris Ng's Avatar
I'm with stupid -----^
With the recent threads about going to hybrid turbos, I figured I would just post a few pics of my setup:
Stock series 4 Turbo on the left, TO4 compressor on a series 5 turbine side..
Side shot of the 2 turbos, notice how the exhaust inlet is angled diffrently on the series 5, the series 5 exhaust manifold's are completely diffrent from a series 4.. if you plan on doing a swap, you'll need the newer manifold.. Notice the equal sized ports as well.. no more twin scroll door..
Last, a shot of the turbine side.. the turbine wheels are about the same size on both turbos, but you'll notice the angle of the blades are diffrent..
Note the larger wastegate door as well..
Old Jan 27, 2002 | 06:31 PM
jspecracer7's Avatar
1JZ powered
FINALLY!!!
Someone who has done it AND posted pics. I wanted to do this to my FC when I owned it for awhile before I went LARGE single turbo.
Now that I've got my FD though...T-04S on the way...
Old Jan 27, 2002 | 06:42 PM
Erik's Avatar
Best of both worlds
awesome pics man!
Old Jan 27, 2002 | 08:56 PM
TonyTurboII's Avatar
Glock Lover
So that will bolt to the stock manifold? How much HP is it good for?
Old Jan 27, 2002 | 09:16 PM
Turbo Timmy's Avatar
Professional Lurker
Would that bolt to the HKS manifold? It's pretty cheap I think...
Very nice where did you get it? I want!
Old Jan 27, 2002 | 11:18 PM
Chris Ng's Avatar
A T04 compressor housing + wheel + backplate will bolt to the center+turbine section of a series 4 or 5 turbo.. a series 5 turbo is preferable because of it's enhanced turbine section.. The turbine section of the series 5 allows for quicker spool + better boost control (ie: less spikeing and creep) due to it's larger wastegate..
People hae made hybrids with the series 4 turbos with good results as well.. just make sure you port the wastegate as much as you can..
No matter what turbo you use, you must remember to use the matching exhaust manifold.. they are not interchangeable..
some things to watch for:
a 60-1 Hi Fi TO4B compressor is probably the largest you can bolt on that won't present fitment issues when bolting on the turbo (Compressor housing hitting the lower intake manifold)
The stock wastegate actuator will have to have one of it's mounting holes on the bracket notched or enlarged in order to mount on the back of the compressor housing (spacing is diffrent)
You may need to install a nipple either on the compressor housing or the aluminum pipe (One that the BOV connects to) for the wastegate hose to connect to (If you look at the pics above, the hybrid compressor housing doesn't have a fitting on it)
When installing a series 5 turbo into a series 4 motor, you will want to use the series 4 oil and water lines .. they will hook up with no problems.. the series 5 lines will not hook up to the series 4 block..
The series 5 turbo to manifold gasket is diffrent from the series 4 gasket, so you can't reuse it.. however the series 4 manifold to block gasket will work with the series 5 manifold..
You'll need to do the TID mod since the turbo inlet is larger on the TO4 then the stock hitachi
Depending on the compressor wheel/housing combination you choose, and if you modify the turbine wheel at all (get it clipped etc) I would estimate you being able to hit anywhere betwee 250 - 290 rwhp
Old Jan 27, 2002 | 11:27 PM
Glock Lover
So I can just modify my stock turbo? Im going S5 here real soon...It sounds like basically all im re-using is the center section?
Old Jan 29, 2002 | 02:35 AM
Jerk_Racer's Avatar
I bought a series5 turbo just for this. If anybody has a write up, please post it. I don't feel like reinventing the wheel.
jerk_racer@hotmail.com
Old Feb 22, 2002 | 06:23 PM
InfiniIIIREX's Avatar
man, now I am seriously considering getting this done.
Old Feb 22, 2002 | 06:31 PM
Felix Wankel's Avatar
Super Newbie
You're reusing the center and the hotside.
Old Feb 22, 2002 | 06:41 PM
live4boost's Avatar
AKA ShepFC3
THis is a good cheap upgrade. Im gonna do it as soon as I get around to it. I need to get my T04 back from my friend. Did you see my post under the single turbo forum. If not please respond. I have a few more questions on this.
Old Feb 23, 2002 | 12:59 AM
Supermac's Avatar
I have a friend with a T04B 60-1 hifi compressor housing, stock exhaust manifold, and stock engine block thats making 360 at the wheels, ran an 11.9 at the track with this setup.
Old Feb 23, 2002 | 02:48 AM
HWO's Avatar
HWO
inteligent extratarestril
i have it on good authority from a certain guru on this forum, that if you are gonna do a hybrid with a 60-1 compressor, you are better off with a S4 turbo to start with, due to the entry angle of the exhuast gas onto the turbine blades they dont suffer from the same surging problems the S5 turbo's do. just a little food for thought. add an external wastegate, dail up 20psi and hang on
Old Feb 23, 2002 | 11:22 AM
Does anyone know what size the stock Turbine housing is?
Could you not just put a Devided T04B turbo on the stock manifold or would this not work?
Old Feb 23, 2002 | 11:54 AM
RETed's Avatar
1.00A/R is about the only info that can be dug up on it.&nbsp The rest is a proprietary Hitachi design.
No, you can't do that - at least not very quickly and easily.
-Ted
cristoDathird
28
May 30, 2019 08:47 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
Machupicchu
Aug 17, 2015 08:27 PM
