13b 6 port non turbo
Old Nov 30, 2005 | 10:39 PM
JerseyFc's Avatar
Hi, I have a 13b 6 port non turbo in my fc. It has racing ports high comp rotors and 3mm apex seals. It has race exhaust with no cat ram air intake, race pulleys and other small goodies. What kind of hp should I expect out of this build? How could i get more power out of it? Whats a good 1/4 mile time for n/a fc? O and it has 12.5lb flywheel
Old Dec 1, 2005 | 12:18 AM
Icemark's Avatar
well the gains from lighter rotors are probably lost by using 3mm seals.
Whya re you using 3mm seals??? Planning on using mega boost or major amounts or NOX?
Old Dec 1, 2005 | 01:30 AM
Jager's Avatar
Tear you apart
Race ports? Like a bridge? Or just a large streetport? Done by whom?
Old Dec 1, 2005 | 09:17 AM
Aaron Cake's Avatar
Engine, Not Motor
If the body is stock, you'll see maybe high to mid 15s with that setup. But you're very vague on what all your "race" goodies actually are.
Edit...BTW, if you really had "race" ports (bridge, J or peripheral) and a "race" exhuast, the car would be insanely loud to defening levels.
sherff
Feb 24, 2019 12:09 PM
Engine stand ready
Aug 14, 2015 10:26 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
