no clicky click when i turn ignition on HELP!!!
Old Nov 29, 2005 | 10:30 AM
c.stenson1's Avatar
rx7philrx7
Question no clicky click when i turn ignition on HELP!!!
ive been messing with my car and now i cant start it. when i turn on the ignition there is nothing no clicks like there use to be. have i blown a fuse or something, please help, cheers phil.
Old Nov 29, 2005 | 11:06 AM
c.stenson1's Avatar
rx7philrx7
when i say theres nothing i mean i cant hear any clicks, it still trys to start but it cant for some reason, i have just checked the fuel pump relay and there is no power at any of the terminals and that doesnt click either. so it must be a fuse of some sort, can anyone guide me in the right area, cheers phil.
Old Nov 29, 2005 | 11:23 AM
Mahjik's Avatar
Mr. Links
Start with listing the things you changed or touched since it was working.
General rule, if it was working before you touched it, recheck your work.
Old Nov 29, 2005 | 11:40 AM
c.stenson1's Avatar
rx7philrx7
what could i have done to make the fuel pump not have any power, i never did anything apart from moved the long relay box about (its a bit loose on my car,) and wiggled a few other wires, is there a fuse that could have blown if a wire was exposed.
Old Nov 29, 2005 | 11:51 AM
Mahjik's Avatar
Mr. Links
There is a fuel pump relay. Did you check that?
Old Nov 29, 2005 | 12:01 PM
c.stenson1's Avatar
rx7philrx7
yes that still works when wired to a battery but not when i put it in the housing, thats why i wondered if a fuse had gone.
Old Nov 29, 2005 | 01:28 PM
areXseven's Avatar
il Cosa Nostra e vivo!!
From: Dove le cose sono fatte il vecchio moda il senso
Check the 120A Main Fuse. It's located in the rectangular shaped fuse box that's connected to the positive battery post.
Old Nov 29, 2005 | 01:37 PM
c.stenson1's Avatar
rx7philrx7
thanks for your help people, i posted another thread about fuses and found that the fuse box above the drivers kick panel had a 15 amp fuse gone, this fuse made my car just turn over with no signs of starting, its great now, cheers.
The1Sun
Sep 15, 2015 04:45 PM
meetRoX7e
Sep 11, 2015 11:09 AM
astrum
Sep 7, 2015 11:41 PM
