Wiper relay
Old Jan 26, 2002 | 07:33 PM
Question Wiper relay
You guys know where I can buy one? Because guess what, my wipers only work on one setting!!! I know I know weird thing huh, must be the first with this problem
thanks guys
Old Jan 26, 2002 | 07:47 PM
StarionX's Avatar
I had a similar problem (and my rear wiper wouldn't work at all). I got a reconditioned one from RX-7 Heavan here in Ottawa, Canada. Cost me CA$150 plus the old wiper relay (CA$175 without). This one works like a charm (even the rear wiper )
They have ones for different models.
Old Jan 26, 2002 | 07:53 PM
I am looking for just the relay because I am not an idiot and I can replace it myself if I need to.
Old Jan 26, 2002 | 08:05 PM
t_mak@mail.plymouth.edu's Avatar
Digikey sells it
Old Jan 26, 2002 | 09:30 PM
Wankel7's Avatar
Haven't we ALL heard this
Try this...click on the search function of this page. Then search for, "Wiper relay" and you will find many past discusions on this. There should be a page that has all of the parts you need. It is very through.
James
Old Jan 28, 2002 | 09:09 PM
HAILERS's Avatar
HAILERS
This relay G5LE-14 DC12 PCB RELAY and this relay G6C-2117P-US-DC12 Subminiature Moving Loop Power PCB Relay I ordered this hour from this site http://omron.ca/c/htmlos/00399.1.896...ProductListing
I ordered three each for the three ones laying about the place here. The big one is the G5LE and the lower one is the G6C. I have never replaced them before, so I can't vouch for the results. I used a soldering wick on the removal and did not overheat anything. You just have to have a soldering wick to remove them, in my opinion. Maybe a buck from Radio Shack.
The shipping cost as much as the relays. But that is to be expected. By the way, DIGI-KEY did not have the G6C, thats why I resorted to the OMRON site in the url.
Old Jan 28, 2002 | 11:47 PM
asherwood's Avatar
Additional tips and tricks!
https://www.rx7club.com/forum/showth...&threadid=35372
Good luck!
Old Jan 29, 2002 | 12:55 AM
Icemark's Avatar
BTW: if your order from digi-key you need to use their p/n for the relay which is Z950-ND
Old Jan 29, 2002 | 08:05 AM
HAILERS's Avatar
HAILERS
ASHERWOOD... I read https://www.rx7club.com/forum/showth...threadid=35372 sometime ago and thought it was a very good article, but, when I looked in the DIGIKEY catalog they did not list the small relay under *relays-OMRON*. I also read from another post that another fellow called DIGIKEY and they said they did not carry the relay. They did have the large relay though. So I gave up with DIGIKEY and went to the OMRON site and made the order. They listed the small relay but I used your number for the large relay(they did not list the part # that was on my relay). I'll look at the catalog for Icemarks number and see where I went wrong. Brand new catalog, should have been current.
Old Jan 29, 2002 | 08:37 AM
SureShot's Avatar
Seduced by the DARK SIDE
I took the “crude but effective” approach. I used a big ol’ generic relay, soldered some short leads on the terminals, carried the leads to the board, and duct taped it to the module. I can hear it tick-tock in intermittent mode, but it should last forever.
Old Jan 29, 2002 | 11:42 AM
asherwood's Avatar
Hailers, your right...
Hailers, in the Digi-Key catalog they list both the OMRON number and the Digi-Key number, also remember that Digi-Key does NOT necessary carry the complete line of OMRON relays. I ordered mine from a local electronics retailer and they were able to get them no problem.
The relay the Icemark points out: Z950-ND is a Omron G6C-2114P-US-DC12 which is the same as G6C-2117P-US-DC12 except that one is sealed and the other is not (both will work for us). You are right that Digi-Key does not list the original (big white) relay G8S-117P-FD-04 but Omron does make a replacement one: G5LE-14-DC12 and this one is electrically and physically the same.
From the Omron site these are the pages that I referred to:
http://oeiwcs.omron.com/webapp/comme...54&prmenbr=316
http://oeiwcs.omron.com/webapp/comme...47&prmenbr=316
Hope that this info helps...
Old Jan 29, 2002 | 01:24 PM
HAILERS's Avatar
HAILERS
Asherwood....thank you. Yes, I was eyeballing that 2114P and thinking about why wouldn't that work but never followed thru. Just procrastinated forever. I'll look at their catalog when I get home. Just had a case of the dumb little peckerwood syndrom. I'm hoping that this gets archeived or the other one. Its helpful if one knows the part numbers. I know that the numbers on my relays did not exactly match the ones you quoted in the other post. I figured they used an alternate on the newer cars. Anyway I registered with them and got my password and ordered three each. The help is appreciated.
Old Jan 29, 2002 | 01:35 PM
RX-Revvin's Avatar
Jameco Electronics in Cali also carries the G5LE-14 DC12. I think it's also cheaper than the other company I was looking at for one. It was $1.87 at Jameco. Can't remember if I was comparing it to Digikey or Mouser though.
Old Jan 29, 2002 | 02:24 PM
thanks guys but....
Which one do I need to control the intermittent and fast pace for my front wipers? Thanks
Old Jan 29, 2002 | 04:00 PM
asherwood's Avatar
Any which way it save you a bundle!
When I called the local Mazda dealership the price for the wiper switch assembly (the whole works) he quoted almost made me crap my drawers! He said "it's $735.54, and we'll have to order it!"
A few buck for relays and solder along with the patience to do-it-yourself is worth the effort!
Old Jan 29, 2002 | 04:06 PM
asherwood's Avatar
Re: thanks guys but....
The bottom relay (G6C-2117-P-FD-TM) controls front wiper movements for high speed, park, mist and intermittent.
Please see the thread linked below...
Old Jan 29, 2002 | 04:18 PM
cool, thanks
Old Jan 29, 2002 | 04:28 PM
last link doesn't work btw
Old Jan 29, 2002 | 04:32 PM
what is omoron's part # for the G6c-217-p-fd-tm
Which is the one for intermittent and fast speeds
I couldn't find that # at their site........
Old Jan 29, 2002 | 04:41 PM
asherwood's Avatar
Strange about the link, the same one in 'Hailers' post works, and the first link to the Omron site in my earlier post is for the relay you want,
G6C-2114P-US-DC12 or G6C-2117P-US-DC12 they are pretty much the same.
The numbers on the relays found in the switch are from Omron Japan...
Old Jan 29, 2002 | 05:57 PM
hey thanks, hope to get it done right, I'll let you know if I did, see ya around
Old Jan 29, 2002 | 07:01 PM
HAILERS's Avatar
HAILERS
I copied and pasted both links, and when they are pasted like the above, they turn out different. Got me. Just a curiosity.
EDIT: Well darn. When I first copied and pasted, they showed up different, even though they looked the same when I copied them. But when I completed this post, they both turned out the same.
For those who are interested in trivia, take my url and paste it to a Word document. Then take Asherwoods and paste it just under where you pasted mine. Once pasted, they look different. Trivia.
Old Jan 30, 2002 | 01:59 AM
asherwood's Avatar
Weird science!
When I try the top thread link it works, but the lower one does not?
Ghost in the machine?
Old Jan 31, 2002 | 12:42 AM
crosbo's Avatar
The links are different. Place your pointer over each link and you will notice that only the top link is valid.
Old Jan 31, 2002 | 05:47 AM
HAILERS's Avatar
HAILERS
If you copy each link, and then paste to a word document, you'll see they do not look alike anymore. Try it.
