Rx-7 heater sux in the winter!
Old Jan 26, 2002 | 06:18 PM
StarionX's Avatar
I know that the Logicon unit for the heater is not the best, but what sort of heat can I expect to get in the winter? I literally have to warm the car for at least 10 minutes with the fan on full blast, before I can actually get in the car without freezing my *** off.
Old Jan 26, 2002 | 06:25 PM
SpeedRacer's Avatar
Formula Mazda Driver
My heat used to be great, and it used to heat up quickly. I just changed my thermostat, and now it takes FOREVER. I just recieved an OEM thermostat, that I'm putting in tommorow. Hopefully that will fix my problem. I'll let you know if that helps me. If so, a new thermostat is only like $10 or something.
PlayinW/Wankel's Avatar
tuffen up wussy. just kidding, maybe there is some sort of problem with your heater because mine will warm up in like 3-5 min.
Old Jan 26, 2002 | 06:35 PM
Brian_TII's Avatar
Re: Rx-7 heater sux in the winter!
Mine takes a few minutes before it warms up enough to get warm. Once the car warms up... I've found it to have some of the HOTEST heat around...
Old Jan 26, 2002 | 07:07 PM
Scott 89t2's Avatar
SOLD THE RX-7!
umm, the heater has nothing to do with how fast it gets warm in the morning... if you left your heater off the engine would warm up faster. your engine needs to heat up before it can blow warm air. leave your heater off or at full cold for the first 5 mins then turn it on.
putting a mazda thermostat would probably help it to id you don't already have one in.
Old Jan 26, 2002 | 07:14 PM
StarionX's Avatar
Hmmm, ok. I will try leaving the heater off when I warm up the car. Oh, and I did have the thermostat replaced about a month ago (Mazda replacement). I also replaced the Logicon unit with a second hand one about a year ago (the original, just didn't work at all).
Thanks people.
Old Jan 26, 2002 | 07:17 PM
StarionX's Avatar
Hehehe... I hate the cold!!! Since I'm from Australia, I have to say that the weather here in Canada, without a doubt, really SUX!!!!!!
alfred1976
1st Gen General Discussion
Oct 1, 2017 09:51 PM
Hipsiguy
Sep 14, 2015 05:25 PM
risingsunroof82
Sep 7, 2015 01:11 PM
