help?
Old Nov 27, 2005 | 03:31 PM
rotoryrex94's Avatar
help?
sry to bug you all...ok so i just got my FD...its soo sweet its black with tan leather interior really really nice but there are a few small things wrong with it.....the passenger window won't roll down at all.....do u think its a fuse or something bigger..? any suggestions on where to go and what to do to fix it?
Old Nov 27, 2005 | 03:49 PM
Mybaby's Avatar
window
The motor on my passenger side decided to give out after 30K on my FD(95 White Touring, original owner). You can try swapping out the fuse that controls the driver side window motor. An indication that it is the window motor, the wondow
would slowly go down making a sluggish noise. (This does seem to be the case)
You say that the window does not even move when you push down on the control. What it is sounding like is the connection is bad. You will need to take the interior door paneling off and check to make sure that the connectors click when you push them together securing a feed to active the window motor.
Hope this helps
Street Devil
95 White Touring (a)
Pettit intake
Blitz SMIC
99 Twins
HKS Down
Bonez Mid w/resonator
Racing Beat Dual Tip
much more giving my Auto Devil to high HP's
Sgtblue's Avatar
Urban Combat Vet
Congratulations on the car. Sounds nice. Check the fuse, but otherwise I'd pull the door panel, check the connections and check for power to the motor and work backwards. Maybe this will help.
http://fd3s.net/window_fix.html
That site has a lot of good info on for a new owner
https://www.rx7club.com/showthread.p...ght=door+panel
^Info on panel removal
