Ball bearing questions
Old Nov 26, 2005 | 11:27 PM
4CN Air's Avatar
DETH TRP
Is it safe to have a ball bearing turbo with a dry center section?
Are turbonetics center sections interchangeable between ball bearing and non? I mean just the bare bearing housings. Like if you had a dry center BB turbo and wanted to make it water cooled you could just get any "bigshaft" turbonetics center housing even if it were previously used with journal bearings?
Old Nov 28, 2005 | 01:43 PM
Zero R's Avatar
Just in time to die
On Garrett units it is not, so if it is Garrett based I would say no to all above.
-S-
Old Nov 28, 2005 | 01:50 PM
4CN Air's Avatar
DETH TRP
it's a turbonetics single ceramic BB. A dry center T66
also are the BB center housing (empty bare housings) the same as the big shaft journal bearing housings? Like I could buy a new water cooled housing and swap everything in? Worth the effort? I'll be running full synthetic oil so I'm not worried about coking, but I'm ot sure how picky the BB is.
Thanks for any help you can give.
- Cody
Old Nov 28, 2005 | 02:59 PM
Zero R's Avatar
Just in time to die
I have no experience with the T-netics units. I wouldn't be able to give you correct answers and don't want to give you bad info. I do know back in the day ceramic BB's were prone to fail this was back in the early 90's though.
Old Nov 28, 2005 | 03:51 PM
dubulup's Avatar
development
why don't you want to run coolant thru the turbo? 13B's are already equipped to do it
Old Nov 28, 2005 | 04:09 PM
MrDirt's Avatar
Having a wet housing might add a little complexity (or rather, retain it), but having the option for a water cooled turbo should be taken advantage of whenever possible. I would really suggest going for it if you can, unless you just plain don't need it.
Old Nov 28, 2005 | 08:44 PM
4CN Air's Avatar
DETH TRP
I think you guys are misunderstanding. I'm going with a single turbo, and I knwo the advantages of a wet vs. dry housing. I'm saying I foudn a deal on a dry center BB turbo and wondering how everyone feels this will work out in the long run.
Thanks,
- Cody
Old Dec 7, 2005 | 07:45 PM
4CN Air's Avatar
DETH TRP
I called Turbonetics, they said 95% of the turbos they sel are dry centers. They said it's fine for the BB. Also that the housings are totally different than the nonBB center sections because the actual BB is larger than the journal bearings (I should've known that).
Also FWIW they said a restrictor is not needed, that the little filter that they include in the oil feed adapter is sufficient. Also they recommended -3 feed and -10 drain. I'm using a 3/16" hard brake line (I cut off and tapped the stock banjo, which should also help as a restriction) and 5/8" rubber drain line (will replace with silicone soon). The drain ID is never less than 1/2".
Old Dec 8, 2005 | 05:41 AM
RETed's Avatar
Turbonetics mills out stock Garret CH's (or do they make their own now?) just to retrofit their bearings in them.
No, they are not interchangable with anything out there.
-Ted
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
gabescanlon
Sep 5, 2015 12:04 AM
