How many springs does my HKS 60mm Wastegate have?
Old Nov 26, 2005 | 04:32 PM
LUPE's Avatar
I have a 10lb spring in it now and I am wanting to buy a 20-22 lb spring. Problem is, I go to HKS's website and they list a center, outer and inner spring..... Which one do I get?
Check it out,
http://www.hksusa.com/products/more.asp?id=1472
Old Nov 26, 2005 | 09:41 PM
LUPE's Avatar
Anyone know?
Old Nov 27, 2005 | 09:08 AM
LUPE's Avatar
seems like a simple question.... anyone?
Old Nov 27, 2005 | 09:35 AM
rizzxx7's Avatar
DIGG7ER
you most likely only have the outer spring, you can probably buy another spring that adds to your existing 10 lb spring. my tials have 2 spring to make 17 lbs
Old Nov 27, 2005 | 09:38 AM
LUPE's Avatar
I wish I knew for sure before I started ordering parts that can't be returned.
Old Nov 27, 2005 | 12:42 PM
Xcessive's Avatar
When they come in the factory box, three different springs are included, which you can mix and match from like 6psi up to 26psi.
Old Nov 27, 2005 | 02:21 PM
LUPE's Avatar
mine came with my hks t51r kai kit... so no other springs were included.
Do you know which spring I would need for for a 22lb spring?
Old Nov 27, 2005 | 05:42 PM
LUPE's Avatar
my wastegate came with my hks t51r kai kit... so no other springs were included.
Old Nov 27, 2005 | 07:02 PM
Jim Swantko's Avatar
They usually come with a 1 bar spring (white/blue)... if you want a base boost of 20-22 then you need to use the white/blue and the silver then adjust the gate until you get the boost you want. One spring will fit inside the other. Be careful when opening it however - those springs are pretty damn strong. Also - I'd recommend a vise for putting it back together.
Edit - this is just for the GT gate... the GT2 is totally different and much better IMO.
Old Nov 27, 2005 | 07:06 PM
LUPE's Avatar
hmmm, do you have a link to this silver spring?Nevermind, I see what you're saying........ thanks. Ordering the silver now.
I don't need a vice..... I've got the strength of a baby donkey.
Shainiac
Jul 17, 2019 02:20 PM
