radiators (yeah, I know I know!)
Old Nov 24, 2005 | 06:01 PM
bajaman's Avatar
Constant threat
Is this one from RADIATOR WORLD the only one that is basically like the stock unit, where it has the fittings for an automatic transmission? I am going to replace my radiator as part of my engine rebuild, since I had done the block-seal-in-a-can routine a few times and don't want any contaminants in my new engine, nor do I think the old original radiator is likely up to spec on cooling efficiency.
http://www.radiatorworld.com/radiato...px?carno=15108
Any other radiator links for units that have the fittings for an automatic?
Old Nov 24, 2005 | 06:38 PM
mgoddard1's Avatar
I luv my carbon footprint
3rd gens have a separate transmission cooler where the secondary oil cooler normally goes on the passenger side so I'm pretty sure the radiator is the same for a manual and an automatic. You're thinking of a radiator with an integrated transmission cooler in it which the 3rd gen doesn't use.
Old Nov 24, 2005 | 07:03 PM
poss's Avatar
Slower Traffic Keep Right
I'm pretty sure there is a different rediator for an auto...no I'm really sure.
I don't know if the stock cooler is sufficient on it's own.
Old Nov 24, 2005 | 09:30 PM
badddrx7's Avatar
All Spooled Up
The automatic model has a radiator with a cooler in the bottom (stock ), then the flow of transmission oil passes thru the pass. side oil cooler and back to the tranny. You can elimiante this cooler in the radiator though, I did when I was automatic and bought the ultimate radiator ( which does not have a tranny cooler in it )
tom
Old Nov 25, 2005 | 02:58 AM
TpCpLaYa's Avatar
T3DoW
yes the stock 3rd gen radiator does indeed have an integrated trans cooler on top of the cooler where the 2nd oil cooler usually sits. However a manual car can still use an automatic trans radiator by just not utilizing the cooler.
Old Nov 25, 2005 | 05:35 AM
bajaman's Avatar
Constant threat
I just want to keep things as 'stock' as possible, as far as fitment and fittings go. I have an automatic, so I either need the radiator that accomodates it, or else I'll have to add an additional cooler (in addition to the one already on the front of the car) to insure adequate tranny cooling....but I would much rather just have a radiator that had the fittings. So far, only the radiator world one has been one I found in all my searching, including every post I could find on the subject. It looks like FLUIDYNE and KOYO do not offer a radiator like I want.
Old Nov 25, 2005 | 07:49 AM
dgeesaman's Avatar
And unless you're tracking it where you want the extra cooling capacity of a Koyo or Fluidyne, there's nothing wrong with getting an all-aluminum stock sized radiator.
Dave
MidnightOwl
Sep 25, 2015 10:24 PM
